RFID Door project ?
Is there any completed code / schematics·for an RFID Door? I seen the video but didn't see any SX/B code listing for it or schematics. Anyone know? I have a backyard cabin finished into a lab work area that I would like to "techify" it starting with security at the door. I don't have a great mechanical background and don't know much about·installing door handles or keypads, etc. but a good set of instructions·or a·"kit" would be helpfull. ·
I don't have a great mechanical background and don't know much about·installing door handles or keypads, etc. but a good set of instructions·or a·"kit" would be helpful.··
door handles
Take a look at this· very easy to install and work on you can run off of 24 volt @·220 mill-amps or· 12 volts @·440 mill-amps·····
·http://www.kele.com/Access-Control/Manufacturer/SDC/1581V.aspx
The type that go in the door handles are very hard to install and hard to·work on and·they do not last very long
·In another life I use to work on these and.......>>>>>
I think they are Smile··
keypads
If you have a milling machine you can take a plastic electrical box and cut out the opening for the key pad if you do not you can PM me and I can cut it out for you
I hope this Helps
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/1/2009 8:39:39 PM GMT
Re: SX and RFID -- the RFID reader sold by Parallax is quite simple. A few serial statements in SX/B and you should be on your way.
Basically the maglock and it's electronics bolt/screw into the wall right at the top of the door frame and the plate screws into the top of the door. When the door is closed, the plate just touches the huge electromagnet in the maglock -- when energized, the magnet prevents the door from being pulled open (that's the rating: 650lb means it would take 650lbs of force to break the magnetic force on the plate; the door would probably crack before the magnet would "let go").
·Is this something I could get at Lowe's or I must get on-line?
I only place that I have seen these are on line now you might find a lock smith shop they might get theme for you
I wasn't quite able to follow how this is mounted.
·The type that I·have in the link has a plate that mount to the door and the electric magnet mounts to the door frame
Like ZOOT said in his Post it is very esay to install
··Thanks for any·
Sam
