Stingray Robot — Parallax Forums
Stingray Robot
sailman58sailman58 Posts: 162
edited 2009-10-07 17:37 in Robotics
It looks like I get the honor of starting this thread. I will have to order one when I return from a weekend trip.
Anybody else want to comment?
Ron (aka sailman58)
  • PyrotomPyrotom Posts: 84
    edited 2009-10-01 15:59
    I just read through the Stingray documentation, and it looks very detailed and complete. I did notice one error - on page 17 the layout of the control board has items 16 and 17 labels swapped. I doubt this would cause anyone confusion, though.
  • SRLMSRLM Posts: 5,045
    edited 2009-10-01 18:35
    Some tests would be nice to demonstrate what capabilities to expect. I know that Parallax must carefully choose what projects to work on, so take this as a consideration. All the tests should be done with a Nimh or Lipo battery of about ~7.5v and ~3000 mAh. A partial wish list of tests:
    -Maximum speed
    -Maximum acceleration
    -Maximum range
    -Maximum slope going up
    -Minimum slope going down
    -Maximum spin rate
    -Maximum weight (with reasonable wear)
    -Maximum pulling force
    -Maximum negative acceleration (stopping)
    -UV resistance
    -Maximum ground "shagginess"
    I know most of these tests are affected by the user setup and floor material and a million other factors, but it would give an idea of what to expect.
    BTW, very nice robot!
    Edit: a side note, but I noticed that in the "Pings on a Stingray" source code that the MIT licence was in a CON section, instead of a DAT section. Is this a new unofficial standard?
    Post Edited (SRLM) : 10/1/2009 6:45:06 PM GMT
  • John AbshierJohn Abshier Posts: 1,116
    edited 2009-10-01 19:46
    Once the Stingray is assebled, how do you change the batteries?
    John Abshier
  • WhitWhit Posts: 4,191
    edited 2009-10-02 01:33
    John Abshier said...
    I guess it depends on how fat your fingers, hands and arms are... smilewinkgrin.gif As OBC says. He adds another reset button to his Protoboards. I am similarly fat fingered.
    But you should be able to remove one of the Sensor Mount Plates and change·them easily. Also if you use rechargables (which·are recommended), you might make a recharging adapter that could plug into the battery wire connectror.
    I did not see anything in the documentation that addressed this issue (though I've only quickly looked through it).
    Whit+
    Post Edited (Whit) : 10/2/2009 7:05:28 PM GMT
  • KyeKye Posts: 2,200
    edited 2009-10-02 04:07
    This is to Parallax:
    I'm actually quite interesting in buying a string ray robot. It has a very good body and setup. However, some things I wonder about include...
    The batteries (6 AA???) - How long is that gonna last. Like 10 min? What are the test results Parallax has on battery life? If I purchase this robot I need it to last for while running arround.
    I ask this because the voltage will fall over time from motor use and from the prop board. So ar arround 5 volts won't the system fail? Or can it dip down to arround 4 before the LDO regulars fail? This is a major concern. Since the batteries are feeding the logic and motors at once.
    Also, is there any easy way that an encoder could be used on this? I can buy external hardware but it would be nice to know if Parallax has any suggestions for doing this. I hope this was considered in the design for future upgrades.
    Thank you,
    Nyamekye,
  • TimmooreTimmoore Posts: 1,031
    edited 2009-10-02 04:34
    Kye, I asked about encoders for the 7.2V motor kit which uses the same motors as the Stingray in this thread http://forums.parallax.com/forums/default.aspx?f=10&m=385104
    edited 2009-10-02 14:12
    The battery pack would dead-dead by the time it reached 5.5 to 6.0 volts. With NiMH rechargeables I wouldn't repeatedly run them below 1v per cell under load. With NiMH the voltage is going to drop to about 7.2-6.9V pretty quickly and then linger there for most of the battery life and then it falls like a rock towards 6v right at the end. You'd want some kind of lockout to shut it all down and keep it off once you hit 5.5v or maybe 5.9V for rechargeables it you intend to run it till exhaustion. I'd do that no matter what actually.
  • dandreaedandreae Posts: 1,375
    edited 2009-10-02 14:22
    I used a long skinny screw driver and I was able to replace them all (rechargeables).
    Dave
    John Abshier
    Dave Andreae
    Parallax Tech Support·
    edited 2009-10-02 14:24
    I ran mine for approximately 30 min. on rechargeables.
    Dave
    Kye said...
    Thank you,
    Dave Andreae
    edited 2009-10-02 16:37
    Another suggestion: the Stingray product page should have under related products the ping and ping stand, since IIRC the ping stand is built to fit the Stingray (or vice versa).
  • Steph LindsaySteph Lindsay Posts: 767
    edited 2009-10-02 17:15
    Pyrotom said...
    Thanks Pyrotom!·The picture is correct but the line items are swapped in the list underneath. It's correct in the detailed descriptions in the sections that follow.··I've fixed it for the next revision -- the possibilities are endless·here so I'm sure we are going to be adding more material as time goes on.
    -Stephanie Lindsay
    Editor, Parallax Inc.
  • Brandon C.Brandon C. Posts: 106
    edited 2009-10-02 22:28
    Are you guys at Parallax planning on making a video of the Stingray in action?
    No purchase necessary. See back panel for more details.
    Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
    edited 2009-10-03 01:15
    Hey All,
    Wonder how one of those RC Car/Truck batteries would work. Something like this? http://www.onlybatteries.com/showitem.asp?ItemID=14501.55&cat1=12&uid=1010
    7.2 Volt 4200 mAh NIMH Battery Pack - Tamiya Plug
    Specifications:
    Voltage: 7.2V
    Capcity: 4200 mAh
    Chemistry: NiMH (Nickel Metal Hydride)
    Size: 6 x Sub-C Cells
    Configuration: 2 x 3 - Flat Stick Pack
    Connector: Standard Tamiya
    Dimensions and Weight:
    Length: 5.35" (135 mm)
    Width: 1.81" (45 mm)
    Height: 0.91"(25 mm)
    Weight: 12.31 oz (349 g)
    Whit+
    400 x 300 - 20K
    edited 2009-10-03 01:23
    Shoot, Whit - I just got finished putting my Stingray together (yes, it came today - Thanks, Parallax!!), and already you're tempting me to start spending money I don't have on it! Seriously - this looks like it would be a good battery pack for the stingray. Of course then you need the charger to go with it:
    http://www.onlybatteries.com/showitem.asp?ItemID=13215.14&cat1=12&uid=1041
    edited 2009-10-03 02:35
    Pyrotom,
    Actually you would want two of the battery packs and the charger. That way you could charge one while the other was powering your Stingray! smilewinkgrin.gif
    As per Dave above - a thirty minute run time is pretty good. You can do a lot of playing and testing in thirty minutes.
    Glad you are having fun with your new bot.
    Whit+
    edited 2009-10-03 03:00
    Or you could go with Lipo batteries (2S is 7.4v)
  • RambomanRamboman Posts: 101
    edited 2009-10-03 06:57
    I use a123 packs in RC planes.
    With the appropriate charger, they can be charged in place in 15 min (no need to buy two packs).
    Now you can find 2s2p packs with the same form factor as common NiMh car packs (or DIY).
    It would be a nice idea to add a power switch and a charge plug with balancing taps (3 wires).
    To recommend!
    75 x 50 - 2K
    edited 2009-10-03 07:00
    edited 2009-10-03 14:43
    Having fun with my Stingray, but with no sensors on it yet there is not a lot I can do. I have encountered a problem, though. If I load a very short program into the EEPROM all is well. But if I try to put a longer program in, I get an "EEPROM verify error on COM7" message.
  • curt66140curt66140 Posts: 19
    edited 2009-10-03 21:50
    I just got my Stingray kit today, great kit and very easy to assemble even in a hotel room on business. I brought a supply of parts and sensors with me so I'll be playing when I'm not working.· Thanks Parallax for another great product.
    Curt
    edited 2009-10-04 12:47
    Pyrotom said...
    Pyrotom,
    Maybe·you should·post a question about this over on the Propeller Forum. I've never encountered this problem, but some of the other Prop folks may have.
    Edit - Just found this thread on the Prop Forum - http://forums.parallax.com/showthread.php?p=845454·You may want to contact Parallax's Tech Support. But this still might be a problem someone has encountered and solved.
    Whit+
    Post Edited (Whit) : 10/5/2009 12:14:11 AM GMT
  • sailman58sailman58 Posts: 162
    edited 2009-10-05 12:07
    Back from my weekend trip and I am happy to see activity on this thread. Since I have a couple of full weeks ahead of me, I think that I will wait for my cats to give me a Stingray kit for my birthday next month. While waiting I will be watching this thread for ideas. I do like Whit's rc battery idea since I have a bunch of them lying around for use in cars, boats, and the odd robot.
    Ron aka sailman58
    edited 2009-10-05 19:51
    Hey Everyone,
    I couldn't stand it any longer. The inventory count was down to 22 - so I had to order one. I was going to wait for free shipping!
    At least now I can sleep at night...
    Whit+
    edited 2009-10-05 21:22
    Whit said...
    Or not! [noparse];)[/noparse]
    Usually when I order a robot I get so excited that I cannot sleep until I get it. tongue.gif
    edited 2009-10-05 21:29
    Brandon C. said...
    You're probably right!
    Whit+
    edited 2009-10-05 23:33
    Thanks for the heads up Whit. The count was down to 10 when I told the cats to order early. if they didn't want to be disappointed when they ordered my birthday present. I just hope they don't hide it in the litter box until the big day!
    Ron aka sailmen58
  • doggiedocdoggiedoc Posts: 2,252
    edited 2009-10-06 00:14
    John Abshier
    John,
    I am able to slip a finger in from either side of the tail wheel mount and pop the batteries in and out. If you don't have long enough fingers the ubiquitous Parallax screwdriver can be used to gently pry them up for swapping.
    BTW - Parallax - thanks for the prompt shipping! This is a best Birthday present I've gotten in 42 years!!
    Doc
    edited 2009-10-06 00:16
    Holy Smoke! They are going like crazy. The inventory count is now 9.
    CONGRATULATIONS Parallax! Looks like the Stingray is going to be a winner. Better start making a few more...
    Whit+
    edited 2009-10-06 00:24
    The first time they were in stock, there was 48 of them.
    edited 2009-10-06 00:32
    Brandon C. said...
    Looking at your signature begs the question in my mind: Is the Propeller Robot board backward compatible with Boe Bot? Hmmm....
    Doc
    ON EDIT: thought it might be worth a shot to put the Stingray board on a Boe-Bot but the BOE is slightly smaller. So that's a no-go.
    Post Edited (doggiedoc) : 10/6/2009 12:42:11 AM GMT
