The sample code that comes with the EMIC documentation shows how to get it to say numbers like "65". Since you're sending text to the EMIC with a SEROUT statement, you can use all the features of the SEROUT statement including the ability to take the value of a variable and convert it to displayable form like "65". Read the chapter in the manual on the SEROUT statement for examples and the appendix on the formatters (like DEC).
$00 tells the EMIC that the next bytes should be spoken. $AA, or EOM, means End-Of-Message.
The documentation for the EMIC is pretty good, take a look at it.
Don't worry. Be happy
IF Sign = 1 THEN SEROUT EmicTx, Baud, [noparse][[/noparse]$00,"Temperature, minus ", DEC tmp, " degrees.",$AA] ELSE SEROUT EmicTx, Baud, [noparse][[/noparse]$00,"Temperature ", DEC tmp, " degrees.",$AA] ENDIF▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
i will try it tonight.
·or $00 that is Say and $AA is EOM that right DEv.
Post Edited (Tomvn) : 10/1/2009 4:25:25 PM GMT
