I need help — Parallax Forums
I need help
harbiharbi Posts: 10
edited 2009-10-12 10:42 in General Discussion
hi every one
i am planning to buy· Floating Point Coprocessor· >>>>>>>>
which is better
32-bit Floating Point Coprocessor V2·or· 32-bit Floating Point Coprocessor V3.1
iam using javline JS1-1C
thank you
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-10-01 01:59
    V3.1 is better (faster, plus it gives you 2 12bit A/D converters 0-5V, 2 digital outputs,
    TX/RX with optional NMEA scanning for GPS devices).
    regards peter
  • harbiharbi Posts: 10
    edited 2009-10-02 12:38
    thank you peter
    I will buy 3.1
    also i need this with GPS
    many thankx to u
    I am using uM-FPU v 3.1 with javline
    i got all files that you but in ur website and they are very useful but i need some functions that is not written in these files in java .
    1- MOD function to be used in my code just by call like (add function that is written in java class Math32.java).
    2. CONV function to use FCONV instruction of uM-FPU v 3.1 just by call like add function and parameters will be float32 number and bb num
