New Forum Portal and Toolbar. Improved Search Function (now with OBEX). — Parallax Forums
edited 2009-10-15 03:55 in General Discussion
I've created a new portal for the Parallax Forum that includes a toolbar for searching the forum and for formatting Spin code for submission to the forum. Here's what a typical browser window looks like with the toolbar:
You can access this portal by going here: www.phipi.com/forum. Once you're there, all searches and forum activity will remain within the portal window. Searching is done via specially-formatted queries to search.parallax.com. The code formatter will open a separate window from which the formatted code can be selected and copied to the clipboard.
Give it a try, and let me know if it works for you.
Post Edited (Phil Pilgrim (PhiPi)) : 10/9/2009 5:02:55 PM GMT
640 x 433 - 84K
  • ZootZoot Posts: 2,227
    edited 2009-10-01 01:28
    The search is great -- any chance of getting the topic's title in the results?
    edited 2009-10-01 01:34
    No. I could do it if Google Search allowed regular expressions in the query line, but it doesn't.
    edited 2009-10-01 20:04
    Will this work for other· formatting· code for submission to the forum other than Spin code
    Also is there a direct link to that site or do first have to open Parallax Forum then go to your site
    Look very nice I like it Thanks
    ··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
    Post Edited (sam_sam_sam) : 10/1/2009 8:14:23 PM GMT
    edited 2009-10-01 20:42
    Sam,
    As of now, the formatter will work with any input, but the keyword boldfacing is only for Spin code. What I need to do is add the keyword lists for the SX and PBASIC and include a decision matrix for incoming code to decide which it is. For the time being, the formatter is also available at www.phipi.com/format.
  • WhitWhit Posts: 4,191
    edited 2009-10-02 02:50
    Thanks Phil!
    Whit+
    edited 2009-10-04 22:19
    I've improved the behavior of the "Search for:" box; and now, if you hit enter in that box, it will properly perform the desired search.
    If you use the portal, but can't see all of the toolbar contents because it's not tall enough, please let me know. A partial screenshot would be helpful.
    edited 2009-10-04 23:43
    Too short (Safari) and/or bad alignment (Firefox).
    See attached. First screen is Safari; second screen is Firefox. I run all my browsers with default text sizes, etc, so these are fairly indicative.
    1084 x 593 - 189K
    1081 x 611 - 190K
  • SRLMSRLM Posts: 5,045
    edited 2009-10-05 01:01
    Chrome has a similar cosmetic problem to firefox (the code box is a little bit depressed).
    edited 2009-10-05 03:04
    Thanks for the feedback. Try it now. I've changed the table alignment, forcing everything to "top".
    edited 2009-10-05 04:43
    Better.
    1054 x 650 - 114K
    edited 2009-10-09 17:00
    I've added the OBEX to the list of places to Search. If you're already using the toolbar, just do a "reload" to get the added capability.
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-10-10 19:55
    Thanks Phil - nice improvement!
    You might want to test it in FireFox as it tends to be the most adherent to W3 specs. In FireFox 3.0.14 on Win, it does not display the buttons in alignment with the text and dropdown boxes - "TOP" is usually not enough to fix this.
    Here's a trick I use alot - float DIV tags where you need the objects inside one big div tag that is just inside the body tag, like this:
    <body>
    <div id="div_body">
    Then place those objects inside their own div tags and ID them (or you could try all of them aligned in one div). These/this tag(s) then float on the page wherever you want them. Avoids all the table formatting headaches.
    <div id="div_searchObjects"> Search for: <input type="text" ...> etc etc
    </div>
    -Parallax forum stuff-
    Be sure to close the body div:
    </div>
    </body>
    The trick then is to do this either in a style sheet, or on the page itself (fiddle with the parms - which are arbitrary here - and you'll see how cool this is):
    #div_body{
         width:800px;
         margin-left:auto;
         margin-right:auto;
         text-align:left;
         padding-top:10px;
         background-color:#ffffff;
    #div_searchObjects {
         float: left;
         margin-top:5px;
         margin-right:50px;
         margin-left:2px;
    You might also have to define one as 'position:absolute' and the other 'position:relative' (or vice versa!) to get it to work ... I'm doing this off the top of my head.
    HTH
    - Howard
    Post Edited (CounterRotatingProps) : 10/10/2009 8:02:29 PM GMT
  • doggiedocdoggiedoc Posts: 2,257
    edited 2009-10-10 23:10
    I like it! I sure makes searches easier!
    There are 10 types of people in the world, those that understand binary and those that don't.
    edited 2009-10-10 23:20
    doggiedoc,
    Thanks!
    Howard,
    Thanks for the Firefox heads-up. I've tracked the issue down to Firefox's not honoring the rows parameter for textarea boxes. I've managed to kludge a solution, wherein everything is now aligned to top, and the bottom half of the format entry box is clipped off in Firefox. I didn't want to use up any more vertical space than I had to, since it intrudes on the forum a bit, as it is. It's not as tidy-looking as I might have liked, but it works.
    BTW, I've seen floating elements and understand your comment about them. (At least I think I do, but I'm no web design guru by a long shot!) My reservations about using them are that, in most browsers I've seen, they don't stay put when scrolling, even though they eventually return to the correct positioon when scrolling stops. I just find the delayed reaction a little annoying, and that's why I've resorted to fixed frames.
    edited 2009-10-11 19:46
    Phil,
    you're welcome. Looks better in Firefox now - as long as the doc's window is wide enough. Still crops the bottom as you noted, in IE too.
    FYI, the floating tags *won't* move at all when you scroll if you do the tags the way I mentioned - the div wraping the inside of the body tag gives it a fix reference - that's where the 'absolute' and 'relative' and pixel positioning parms come in. This would also fix the tidyness - and you can pack it in even tighter because you can control the elements right down to the pixel.
    Firefox does honor the rows parm - I just checked that - so it might be another element that's throwing it. I'd guess that the frameset row parm needs to be more explicit than '32,*' or the lack of width and heights on the frames themselves might be causing it. (BTW When things start to get messy, I stop using tables outright and switch to DIV tags.)
    Hey, well that's where scrolling comes in handy! I'd vote for taking up even *more* from that top chunk to buy functionality. It wouldn't surprise me at all if others here thought the same. You've boosted the power of the forum quite a bit with that one line of input boxes and buttons!
    - H
  • ColeyColey Posts: 1,130
    edited 2009-10-13 18:32
    Phil,
    That is really excellent, thank you for sharing it with us all.
    Coley
    PropGFX - The home of the Hybrid Development System and PropGFX Lite
    Hey,
    this is cool !
    Thanks a bunch!
