NMEA Checksum?
······ Hi Folks,
······················I have been working on interfacing a BS2px with a GPS Engine. The commands sent to the GPS Module must have the correct checksum to be accepted. Is there a program out there for the BS2 family or a program that can be downloaded·for XP or Vista for this calculation?·
····················· I am aware that it is the XOR of all bytes between the preamble "$" and the "*". How do you do this "by hand"?
························································································ Thanks,
The other way to do it is to pick one query string that will give you the data you need. Then manually calculate the checksum. Put that query string
into the Stamp program, complete with the checksum. Then, instead of calculating checksum on the fly each time, just fire off the pre-packaged string.
Cheers,
Tom Sisk
http://www.siskconsult.com
Parallax Engineering
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
