Good Ethernet boards for Prop
Parsec
Maybe I'm over-thinking this one too much, but here are the boards I've found for Prop projects. I'm trying to decide which one(s) to buy:
Price is awesome, $19
www.futurlec.com/Mini_Ethernet.shtml
Price is $10 more than above:
ucontroller.com/documentation/PropNICDoc.html
Both boards are using the ENC28J60, so I'm "assuming" (such an evil word) that the stack that was written by Harrison Pham found in the OBEX obex.parallax.com/objects/196/ will work for both boards. Saves time not reinventing the wheel.
RabbitCore- might be overkill since this is an entirely separate microcontroller with its own features, language, etc. A little redundant. $79 is a little steep to achieve the goal of network connectivity. I'm sure it comes with a stack. www.rabbit.com/products/rcm3000/index.shtml
PIC-MiniWEb- $40, wouldn't have to write squat for stack, just interface & write some Prop logic, (although it NEVER ends up being that easy )
www.sparkfun.com/commerce/product_info.php?products_id=7829
The search results from Google go on and on... I had no idea so much hardware was out there. Man, I've been out of the loop for too long! Which board(s) would you all go with? Any pro/cons from your experiences? Spend the ching and get a couple boards, experiment?
No electrons were harmed while rendering this message.
That futurelec board is CHEAP! It usually takes a while to get your shipment from them, but $19 isn't much more than the cost of the ENC28J60.
Gadget Gangster - Share your Electronic Projects
Style and grace : Nil point
Regards.
Alberto.
So, what's the scoop with these Alberto?
Sorry, but these boards are not enough professionally done for sale, I've used them to control a LED screen, like support of another boards.
But if you like, send me a PM with your email, and I will send to you the gerber files of the PCB, and all details, BOM, etc.
All parts are from DigiKey, so you'll have not problems to get it easy.
PS: To sale boards for me is very hard...you know, I've to import all parts from USA, then assemble here, and get back to you, the cost for the boards goes up easily.
Regards.
Alberto.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/27933_HYDRA_EtherX_Manual.zip
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
If you are considering the rabbit/pic solution I 'll suggest you instead a Lantronix Xport/XportAR or Tibbo·(EM203/1000/1202/1206 - wired and wireless available at the same time). The Tibbo solution is really very easy to understand/implement and the development software is free. As·more as I work with it more I like it (4P DevServer, serial splitter, udp tcp, web server/client, ftp server/client, smtp, dhcp, dns, sntp ...)
Another interesting solution (because of the easy way of module/media interchange) is the Multitech Universal socket solution
PEDIT: Don't forget also the [url=http://www.wiznet.co.kr/en/pro01.php?ss[2]=2]WIZnet modules family·[/url]
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
Post Edited (dMajo) : 10/1/2009 9:05:25 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
But I mean they haven't 3.3V regulator on the board, plus a good connector for the VCC & I/O's, also they are hand assemble.
Regards.
Alberto.
Envio editado por (BTX) : 10/1/2009 12:01:42 PM GMT
Here's a tip (actually, there is no "tip" involved [noparse]:)[/noparse] )
If you can get hold of a syringe of solder paste with a nice nozzle you can paste and assemble your smd parts onto the board and pop it into a small toaster oven for a few minutes. Works very well and despite the many variations of this technique with all the fancy profiling etc I just pop the assembled pcb onto a foil tray and slip it in a preheated 220'C oven for 3 minutes then remove it with the foil tray supporting it. Let it cool for a few minutes and it's done. I have employed many techniques for assembling smd parts by hand since I first used smd parts almost 25 years ago (long time!) but this is the best all-round solution for any smd prototyping.
If anyone is interested I might document it up. You don't need to be a micro-surgeon to do this stuff and even ones who are non smd savvy and a little heavy handed have tried this technique and been delighted with the results.
BTW BTX - You could do away with the 25Mhz crystal and feed the clock from the Propeller.
*Peter*
Jonathan
lonesock
Piranha are people too.
@parsec - I've been working on a Video / IP module for the Propeller Platform, I just got prototypes in the mail yesterday. If you want to give the board a try and let me know what you think, I'll send you a kit. Just pm me your address and I'll drop it in the mail.
Post Edited (Nick McClick) : 10/1/2009 6:27:18 PM GMT
Joel-
I saved Earth from an Alien Attack.· Can you?
http://www.joelspennyarcade.com
Yes, I did soldering by hand with a flux gel and a iron solder (a cheap one).
I'm interested too in your comments, I've a syringe of solder paste in my fridge too, but I thought that I need strongly a stencil to put it correctly in the board before owen.
Sure could be a lot of people interested in soldering SMD parts in home though.
Also a bit out of the thread purpose, do you think that a clk generated by propeller counter, is enough stable and capable to drive a CPLD or FPGA clk input too ?
I tried it only once in my DE2 board, and works well, but not in a real working board.
Regards.
Alberto.
Leon
@ Peter, thx for that info, my hands have gotten a little too shaky now to solder SMT chips...!
I think I'm going to pick up the ENC28J60 board from Futurlec since it's just $19, pick up one WizNet WIZ812MJ board for $21 at
www.ewiznet.com/goods_detail.php?goodsIdx=132 (same chip as the module used on the Hydra EtherX, but it's $60) and pick up the YBox2. I figure between these three I can get a good pros/cons list going and still have 3 functional boards (1 for breadboarding, 2 for real projects). Hopefully I'm not cutting a corner here by picking up the WIZ812MJ instead the Hydra board and an edge connector for the goldfingers. The documentation for the Hydra EtherX board is excellent, good docs are impossible to come by. I work for a software firm and it's unfortunate that docs are the LAST thing businesses spend money on... drives me insane
Thanks so much for everyone's input!
Those boards are CUTE!
I want a dozen
@Mike Green
I'm a big fan of LadyAda, she is a great engineer
The YBox2 is a great kit....
"Where am I? Where am I going? Why am I in a handbasket?"
Not only a good engineer, but she writes good documentation and teaches well ... an uncommon combination.
