Argh! Help with g2d12?
Hi everyone!
Okay so here's my issue - I have the g2d12 infrared sensor. I used it last year, and specifically remember that A) I was able to connect it directly to my boe-bot w/o external circuitry, such as the adc8031, and it was able to measure distance (it gave distances from 1-255 or so). It has 4 wires.
HERE'S THE PRObLEM: I can't find the instruction manual to tell me how to set it up again!
So naturally i checked all over the net to find one online, but all of them either tell me how to hook up a 4-wire g2d12, and sense if an object is there at all but it cannot get the distance, OR, they tell me how to hook up a g2d12 with THREE WIRES, using something called an adc8031!!! What's going on?
Can someone help me out here? Maybe link me to a manual i can use?
Thanks!
Thanks!
I think I have docs for that around somewhere, yes, see attachments below.
CAVEAT EMPTOR -- I have no idea if this the version of the sensor you have. Be careful
And I think you're right - it does look a bit modded. In fact I can even see the spot on the PCB where the three pins originally were - it definitely has a built-in ADC. I got it up and running; it's perfect!
I can't thank you enough!
www.hvwtech.com/products_view.asp?ProductID=91
Thanks for that link that was that was a great find to the link to the GP2D12 with on-board ADC
http://www.hvwtech.com/products_view.asp?ProductID=91
··Thanks for any·
Sam
