Blocking Diode and Zenor Diode (shunt)
hmlittle59
I have a my Custom board built around the BS2e...Board is 4x3, (Shift register, DS1302, SSR(3), Resistors). Whats the thought(s) of using a Polarity Blocking Diode and 7.5 shunt Diode to limit the voltage? My first Board was thru hole and I used a NTE 073H 5 vdc 1.5a regulator. The wal mount was 15 volts and need less to say the Voltage regulator got very very hot...(da). Now I'm worried about protection, once I realized the problem, I dropped it down to 8 volts and now....coooool to the touch.
I've noticed the BOE doesn't use them.
Whats EVERYONE's thoughts.....?? thanks
BLOCKING and SHUNT Diode combo on the INPUT.
I'M STILL LEARNING SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
hmlittle59
