loop change for motion detector code
I am working with MEMSIC 2125 accelerometer and this program:
MEMSIC2125-Motion.BS2
I set everything up and the hardware and software works great, but I want to modify the
setup a little. The program is setup to be similar to a motion detector alarm: a light flashes until someone resets the alarm. I want to modify the output. Instead of a light continuously flashing, I want to switch a secondary circuit on. The circuit is turn on with a push button switch. I would like for the Basic Stamp to basically act as the push button switch to turn the secondary circuit on. I spliced the wires from the secondary circuit into the correct output pins on the breadboard. Now here's where I need the help: the "Alarm On" subroutine loops continuously. I need to get it to stop after it "pushes the button" so to speak. Then I need the program to revert back to its original state and wait for more motion to send another signal out.
I'm guessing I need a counter and an if/else statement or a loop/until statement, but I can't
write the code correctly. The code is below.
Please help!
Danny Norman
Knoxville, TN
' File...... MEMSIC2125-Motion.BS2
' Purpose... Detects continuous motion for given period
' Author.... Parallax (based on code by A. Chaturvedi of Memsic)
' E-mail.... support@parallax.com
' Started...
' Updated... 15 JAN 2003
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' Monitors X and Y inputs from Memsic 2125 and will trigger alarm if
' continuous motion is detected beyond the threshold period.
[noparse][[/noparse] I/O Definitions ]
Xin PIN 8 ' X pulse input
Yin PIN 9 ' Y pulse input
ResetLED PIN 10 ' reset LED
AlarmLED PIN 11 ' alarm LED
[noparse][[/noparse] Constants ]
HiPulse CON 1 ' measure high-going pulse
LoPulse CON 0
SampleDelay CON 500 ' 0.5 sec
AlarmLevel CON 5 ' 5 x SampleDelay
XLimit CON 5 ' x motion max
YLimit CON 5 ' y motion max
[noparse][[/noparse] Variables ]
xCal VAR Word ' x calibration value
yCal VAR Word ' y calibration value
xMove VAR Word ' x sample
yMove VAR Word ' y sample
xDiff VAR Word ' x axis difference
yDiff VAR Word ' y axis difference
moTimer VAR Word ' motion timer
[noparse][[/noparse] Initialization ]
Initialize:
LOW AlarmLED ' alarm off
moTimer = 0 ' clear motion timer
Read_Cal_Values:
PULSIN Xin, HiPulse, xCal ' read calibration values
PULSIN Yin, HiPulse, yCal
xCal = xCal / 10 ' filter for noise & temp
yCal = yCal / 10
HIGH ResetLED ' show reset complete
PAUSE 1000
LOW ResetLED
[noparse][[/noparse] Program Code ]
Main:
DO
GOSUB Get_Data ' read inputs
xDiff = ABS (xMove - xCal) ' check for motion
yDiff = ABS (yMove - yCal)
IF (xDiff > XLimit) OR (yDiff > YLimit) THEN
moTimer = moTimer + 1 ' update motion timer
IF (moTimer > AlarmLevel) THEN Alarm_On
ELSE
ENDIF
LOOP
END
[noparse][[/noparse] Subroutines ]
' Sample and filter inputs
Get_Data:
PULSIN Xin, HiPulse, xMove ' take first reading
PULSIN Yin, HiPulse, yMove
xMove = xMove / 10 ' filter for noise & temp
yMove = yMove / 10
PAUSE SampleDelay
RETURN
' Blink Alarm LED
' -- will run until BASIC Stamp is reset
Alarm_On:
DO
TOGGLE AlarmLED ' blink alarm LED
PAUSE 250
LOOP ' loop until reset
Please help!
Danny Norman
Knoxville, TN
' Started...
' {$STAMP BS2}
' {$PBASIC 2.5}
LoPulse CON 0
Initialize:
Read_Cal_Values:
yCal = yCal / 10
PAUSE 1000
LOW ResetLED
Main:
DO
ELSE
ENDIF
LOOP
END
Get_Data:
yMove = yMove / 10
PAUSE SampleDelay
RETURN
' Blink Alarm LED
Alarm_On:
DO
PAUSE 250
Change this line "IF (moTimer > AlarmLevel) THEN Alarm_On" to
Change the Alarm_On subroutine:
There might be additional things you need to do with the code, but it's difficult to give recommendations when you don't provide a schematic.
Don't worry. Be happy
Alarm_On:
' DO
PAUSE 250
' set SecondAlarm
SecondAlarm = ' set second alarm to whatever
GOSUB xx ' process second alarm - include reset ??
GOTO Main: ' return to main pseudo loop but you loose AlarmLED blinking
' LOOP ' loop until reset '
Second option - or include your whole Main in DO ... LOOP
These comments helped greatly. I ended up with this code that works pretty well:
Alarm_On:
HIGH AlarmLED
PAUSE 6000
LOW AlarmLED
PAUSE 2000
RETURN
I also added
LOW AlarmLED
in the else part of MAIN.
Thanks again.
