max7219 idiot requires help pls
Hello All
can someone help me with using max7219 with three digit 7 seg display.I have looked at ex29-change counter & chapter 6 in whats a microcontroller & got totally lost & confused.
using bs2p40, i need to display on specific digits (binary format ((no decode))·from within a·program, how do i initialise & then send to digit ?
see attached txt file for what im trying to achieve
regards Adrian
regards Adrian
http://forums.parallax.com/showthread.php?p=552892
Parallax Engineering
thank you for the info,still beyond my ability to understand.i cannot initialize· on auxio pins 0,1,2 properly & if i get loaded only get "0" on digit 1.
Think i'm better off not using led's & 7219,will just build comps to drive some filament lamps with pictographs.
Help much appreciated all the same.
regards Adrian··
have attached what im using so far,
tried to use pulsout instead of low/high but didn't work.
Bear in mind only running on Proteus vsm not real hardware.
Thanks again Adrian
good heavens i think i've got it.
please have a·look at the attached file. It runs ok on vsm,probably not very good but at least it works
I will try adding to my main program later today !!! and see what happens.
Many thanks again Adrian
