AC Control - Triac
Has anyone (in particular Parallax engineers) built the circuit figure 146.1:SSR Schematic from The Nuts & Volts, Volume 8, Column #146 since the post of InSilico dated 1/3/2009. If yes can we see a picture? Thank you.
Which figure are you referring to? The figures aren’t listed as 146.x they’re listed as 8.x. Also, I saw no reference to InSilico in that column. Can you clarify what you mean?
Parallax Engineering
P.S.: I want to know if it's dangerous for BS2 board due to the fact that "hot" passes through a 180 ohms resistor in the breadboard and what resistor needed if AC is 220 VAC instead of 115 VAC?
I'm going to say probably not. From the article:
"It would take a very hearty soul to tackle this project using point-to-point wiring – and with
120 VAC involved let me suggest that you don’t."
Shawn Lowe
When all else fails.....procrastinate!
As a note…when referring to an article and/or a thread you should link these in your post. Take care.
Although I do not know the reference you speak of......I have built a couple of Triac control circuits.
If you would like to continue off list, you can email me.
I would never post a schematic or circuit on board just for safety reasons. AC voltages should be respected, and are nothing to play with. Doing it right.....and being extremely careful is the mode of operation when dealing with line voltage.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
EFX-TEK, which is partly owned by Jon Williams who wrote that article, sells a board called a FC-4 which dims 120V lights. Give their website a look.
Shawn Lowe
Wow...I didn't know that.....pretty cool.
I should really work on some of the projects I have going...and get them out there for the masses. I'm always too busy putting stuff together for others. Oh well....the story of my life.
James L
James L
Partner/Designer
