Meaning of "IN5"?
Dear all,
I am now working on a project using the Bluetooth embedded transceiver. I am connecting my computer using a Bluetooth dongle to the transceiver.
I keyed in the following command in my program to check if there is any Bluetooth connection between the dongle and the transceiver
Do until IN5 = 1 : Loop
So if there is a connection, the program will proceed to the next command, else it will always be in a loop.
I know the meaning of the number 5, since pin 5 is the status pin of the Bluetooth transceiver.
But what is IN??
Kindly advise...
Thanks and Regards,
But what is IN??
Kindly advise...
Thanks and Regards,
DIR3 = 1
OUT3 = 1
Could also be used - DIR, make an output
OUT3, set output 3 to high
IN5 simply returns the state when it is an input, if input is high or low.
-Martin
Thanks alot for clarifying...
Regards
