141:1 gear motor with quadrature ecoder 7.95 used
i found these and just bought a bunch, and i think this is a really good deal and wanted people to know.
they show up every once in a while, but last time i saw them i hesitated, and missed out, so if you want them get them.
these are made for 12 volts.
http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=12829
there is also a similar right angle version available elsewhere for 11.49, which are made for 6 volts.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16279
and someone wrote up a good description of the motor including the pin out of the encoder here:
http://www.robotroom.com/FaulhaberGearmotor.html
Great find!
Whit+
this looks good - thanks for the update. Thinking about grabbing a few for a little project.
What are you using to control the motor voltage (between the Prop and the motor that is)?
Noting the pulse-per-rev mistake in specs you discovered ...
Would you say that this (from their site) is *approximately* accurate?
" Motors operate from 3-12V volts. At 3V, RPM is approximately 23.6. At 6V 47.2 RPM and 12V, 94.5 RPM. "
At 141:1 it's probably unstoppable, eh?
cheers
- Howard
the rpm state are accurate. i got 23rpm at 3 volts, and 90 rpm at 12 volts. running with a nine volt and those drivers i get about 60 rpm.
they are really powerful, but the shaft is so small it is hard to get a good connection, i cannot stop the shaft with my fingers at 12 volts, and with a 2 inch wheel on it it still requires some effort.
also, the encoders in mine are working fine at a around 3.3 volts.
