PropCore another squared propeller board
ErNa
Hi, the number of propeller boards is increasing, so I announce another version: PropCore.
The intention is to have a small board that can be stacked in at least three dimensions. It will be a multilayer pcb, the back side is completely empty and covered with pads, so additional circuits can be mounted.
The board fits onto the protoboard and allows free usage of all pins. Schematic will follow as soon as the design is frozen.
ErNa
cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
Hello Rest Of The World
Hello Debris
Install a propeller and blow them away
ErNa
Hello Debris
I think it would be interesting to make the board work for more than 3 dimensions...
It seems very similar to on of mctrivia's propmodules. I think he made or was working on a minimum propeller design.
It happens to me much of the time. I like to think that people look at it and don't have anything to add, but it's probably just a poor title. I generally don't spend more than 10 seconds scanning the titles and tabbing the interesting ones, so if it's not immediately catchy or is surrounded by something a bit more catchy, I'm likely to miss it.
"I have not failed. I've just found 10,000 ways that won't work. "
- Thomas A. Edison
I'm getting the impression that there are more boards than applications.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
There are many boards and plenty of applications, I just do not see how to overcome the slow I/O, I mean without losing many COGs. I think mctriia's board albeit too expensive is the way to go.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
As for propgalore i have it archived incase interest comes back but i think infa prop which I am giving away will get more use.
http://forums.parallax.com/showthread.php?p=843716
Post Edited (mctrivia) : 9/30/2009 2:17:14 PM GMT
Out Inner | | ==>|<==>|<============== A | | | | | | ==>|<==>|<============== B | --\ | | | ==>|<==>|<============== C | | | ==>|<==>|<============== DThe outer row is connected to the propeller, the inner row to the outer row on the solder side. if you cut this connection, the prop pin of Board C can be connected from outside, but board B and D are still connected via the inner pin. The serial resistor can be 0R, whatever. There will be additional solder pads to place the ADC and DAC components. So "bussed" pins and single pins are possible in a mixture. More to follow
I use eagle and will publish the schematic and layout as soon as prototypes are verified
Hello Debris
Post Edited (ErNa) : 10/1/2009 11:10:46 AM GMT
