Infi Prop(Why have 8 cogs when you can have an infinit number of cogs)
The octoprop thread sponed this link
http://antipastohw.blogspot.com/2009/08/introducing-illuminato-x-machina.html
thought this would make a cool project to give away. I have started designing a 2"x2" board with a prop at the center to do this.
P0-P7, P16-P23 are taken for inter board communication. so what would you like for p8-p15 and p24-p27?
I was thinking spinstudio header on p8-p15 and p24-p27 leds on board.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Post Edited (mctrivia) : 9/29/2009 4:23:50 PM GMT
By the way, your Propmod1x1 board would also be good for this with optional connector stuffing ... the straight 100mil dual-row headers on the one I bought seem really big.
--Steve
Propeller Tools
Yes 4 io per side. Each square can be connected in any orientation even upside down.
There will be bad for header for programing. Will make compatible with prop clip. Soldering header will be option.
power traces will be 12-40volts with switching regulator to 3.3v(5v pin will not work on spin studio header)
clock will not be shared unfortunately.
Why do you need so many channels between props? I would have thought that 1 TX/RX pair would suffice for each linked pair.
Cheers!
Paul Rowntree
My Propeller to Propeller Intercommunication question could not have come at a better time.
Now, if we could just get Chip to implement intercommunication expansion in the PropII, we
could create gizmo's like this and never need a PropIII. (Hmmm.. might be bad for Parallax)
Can we keep these simple and inexpensive? Prop/Crystal/connectors on each board?
OBC
New to the Propeller?
Would identification be needed? depends on what you want to do with it. names and locations could be automatically identified by network protocols or they could be individually named in eeprom and comunication could be done by mac address.
Almost limitless capabilities.
Assuming 80% efficiency from 12V to 5V
then
ib=0.96V/n
ib=module max current
V=input voltage(12 to 40V)
n=number of modules
Crystal
EEPROM
Prop
power supply
headers
leds.
quick estimates look at a cost of $30-40 each unasembled.
with no power supply and 3.3V input then
ib=6/n
Do you think those worms will fit back in the can...
1) when PropIII...
2) how much memory PropIII...
3) 512 vs 1024 I/O pins ...
Don't laugh, you know it'll happen.
Roger
Actually, when Chip asked me how much memory would be useful in PropII, my
reply was "It doesn't matter how much you put in, we'll all be begging for more in a week."
Human nature I guess... [noparse]:)[/noparse]
OBC
for power I can handle 6A max for the whole grid. with the switching power supplies that is a lot
at 40V 128 modules can draw 300mA each
without the power supply still 20 modules can be powered at 300mA each.
could be stacked 2 high if i forgo the on board leds.
need to pick one or the other:
ib=0.96V/n - is actually formula for with 5v rail
ib=1.45V/n - is formula without 5v rail
ib max is 500mA
Always an option
ib=6/n - without module power supply
so the question is:
5v and 3.3V which allows use of all spinstudio modules but has a max reasonable module limit of 384 modules(100mA each)
3.3V which allows many of spinstudio modules and has a max reasonable module limit of 580 modules(100mA each)
of course limit of modules is only to the number that can be run using 1 common power source. if you split up the grid into 300 module blocks and connect each blocks data lines together but not power than an infinit number of modules could be used.
vga, servo, and ps2. I am thinking it is best to take sacrifice in efficiency to be able to keep these especially servo.
1 of the 2 power supply options is needed.
PCB can be made in panels of 35 for $140(Electrical tested and ROHS compliant) costs an extra $20 if you were to want boards a cool black colour.
I will release gerbers tomorrow so people can get made if they like. I will get a batch made if people want and sell PCB for $10 each.
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
I am tired so will finish this up tomorow morning.
OBC
What about using some of the unused pins on the spin studio connector? The daughter boards dont use them but they are available if you need them.
Probably can't without going to 4 layers but will try.
The board has been designed for minimal part cost and easy hand assembly. If more then 10 people would like me to make boards up I will get them made up and provide bare ROHS compliant PCBs for $10 each.
Legal Stuff:
THE DESIGNS IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
There is a minor error on the schematic. LEDs are shown backwards. This does not effect PCB layout so it was not changed.
I will make up assembly instructions later today.
