Use of the Demo board's mic
I was wondering if anybody has written a spin program using the demo board's microphone. There is one assembly program in the exchange but
I am looking for something simple for this simple mind. I would like to get a numerical value (freq or volume) that
I could use to manipulate led patterns.
the solution depends on what you want.
For getting a volume-value you can use the ADC-object from the ANN1 (Application-Note 1 using the counters
See attached zip-archive. This archive contains a file ADC.SPIN
The shematic Propeller Demo Board Rev D/E/F Schematic (11-29-06) shows the mic connected to PIN 8 and 9
You have to change the PIN-assignments.
This object starts a cog and reads in the ADC-value to variable "value"
Once the value is read in you can do whatever you like with it
best regards
Stefan
www.facebook.com/video/video.php?v=172090980549
Currently fooling with mic-to-headphones OB as ADC, and bitbang PWM as DAC,
for sound and voice changing effects.
I think I have something almost ready with 8-bit sound in and out for an effect BUT
I'm using pin 7 as sound output because 10 and 11 are used up,
and it gets noisier if I try to patch in to the headphones, maybe they're part of a feedback loop.
Mic to VGA O-scope OB was harder to modify for mic use but maybe better for my purpose to try it again.
Part of the problem was cog <-> hub communication and inconsistent seeming effects of using @ symbols.
The microphone is not connected the way I would rather use it, so it's strange to me.
