how to use Jm_softrtc ?
I could use some help
I'm trying to use the JM_Softrtc.spin object to make a set of Leds·change one minute after the RTC starts. I don't see know how to name the variable for the top object
in my object Testtimer1 to see the RTC·or to make it see the one minute mark.
I want to make "pattern" to change to light1 at the one minute mark on the RTC
Thanks BillyS
Thanks BillyS
in the attached file you find a modified version of your code TestTimer1
best regards
Stefan
It was more involved than I was thinking it would be.You do a great job of explaining it in
a way a newbie follow.I will work on following all your sugestions on the proper format.I hope to get as GOOD and helpfull as you are.
BillyS
