tracking my model sail boat on a long journey with GPS
I have a three foot model sailin g boat , very sturdy and sails extremely well . I have used binoculars to not lose it then paddelled out on a surf ski a long way to retrieve it.
I dont know much about the gps yet. I want to fit the boat with a gps and set it off across the world, or maybe a few miles [noparse]:)[/noparse]
How could I keep trck of its location from the shore line ?· Is this even feasable ?
Parallax Engineering
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Don't worry. Be happy
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
Whether it can be water-proofed would be an issue. And you would want to make sure the SOS is disabled, having a rescue team save your boat would be an expensive error.
Not recommending this, just a possibility it could be done.
www.findmespot.com/en/
Thanks everyone, plenty of ideas here to work with.
cheers,
Mick.
You can then use free Instatracker app on your base computer to track locations on a Google map.
Its accurate, easy to install and is fascinating to watch.
Cheers,
Tom Sisk
http://www.siskconsult.com
On the boat you need a GPS receiver, a TNC, and an FM transmitter.· The GPS can be anything, preferably small,·that puts out NMEA-0183 signals over a serial interface; the TNC probably ought to be something really small and light like a TinyTracker, though I use a Kantronics KPC-3+ because that's what I've got; and the transmitter can be almost anything at all.· At intervals the system will transmit a short packet that contains latitude & longitude.
On shore you need an FM receiver, a TNC, and a PC.· The FM receiver can be anything at all that is able to receive the signal from the boat; the TNC can be, for example, a Kantronics KPC-3 or KPC3+; and the PC needs a serial interface that the TNC can talk to, and should be running any of a number of programs that can interpret the APRS packets and display the boat's position superimposed on a map.
There's tons of information easily available; google "aprs tracking" to see some of it.
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 9/27/2009 8:07:30 PM GMT
Here is a compact system that could be be adapted to transmitting GPS coordinates. The handheld transceiver is a Yaesu VX-2 operating on two meters. (Yaesu also makes some waterproof handhelds. This one is not.) It's connected to a (soon-to-be-released) Propeller Backpack board, that peforms the PTT and Bell 202 (1200-baud AFSK) mod/demod functions:
The APRS protocol has not yet been implemented on the Prop (so far as I know). It would make a great project, but it's probably not necessary for a simple tracking app.
The inspiration (and support) for this project came from Ken Gracey and his original thread here:
····http://forums.parallax.com/showthread.php?p=759557
