from 5V to 12 V
I am running my circuit with 5V and if·a conditiion is met I want to·turn a lamp on, the lamp requires 12V.
Can someone help how can I do that? go from 5V to 12V?
Thanks.
Thanks.
- Stephen
Don't worry. Be happy
It's not clear from your post (which the two very different answers you've gotten illustrate) whether you have a source of 12V that you want to switch on and off to control the lamp, or whether you need to create a source of 12V from the 5V available.
I have two external·lamps RED and GREEN, either one·could be ON based on an IF condition, but I don't know how to power up the lamp with 12V.
Preferably I am looking for something I can add to my circuit, or separate but not too bulky.
Thanks for your help.
1) Wiki "Charge Pump"
2) Use the Stamp to switch an external 12V supply to your bulbs using transistors or relays
3) Change your 12V lamps to Ultrabright LED clusters in series/parallel strings that run off 5V
Great dev/null I just love it when it sparkling clear like this! Easy schematics!
Don't get me wrong, I do read all the info, done the book whats a microcontroller twice,read the nuts and volts, but for me, reading gets me nowhere! I learn only with examples... guess getting too old ! I've done the RTFM so many times, I get lost !
Really appreciate great schematics! Seems so easy for you guys.. just incredible! LOL I have not got my head around the law of ohm yet. It does not make sense!
I've read many 101 books about this... still no can do! even the water pressure thingy is still weird.
Sould I start a thread on basic stuff, so you guys can direct a new noob at this?
Cheers
Yosh..
Post Edited (dev/null) : 9/27/2009 7:17:33 PM GMT
