A HB-25 motor controller question — Parallax Forums
hank van burenhank van buren Posts: 57
edited 2009-09-25 06:14 in BASIC Stamp
I have a motor that draws 35 to 40 amps at 12·Volts, ·I want to use two HB-25s in parallel could this be done?
    edited 2009-09-24 14:41
    No. It's not designed for that.
  • $WMc%$WMc% Posts: 1,884
    edited 2009-09-25 00:38
    hank van buren
    The MotorMindB (p#27961) can be used to drive an array of MOSFETs that can take the current.
    Take a look at the IRF4905 and the IRFZ44 MOSFETs. dev/null turned me on to these MOSFETs .(dev/null is a parallax member)
    ___Hope this helps______________$WMc%________
    The Truth is out there············································ BoogerWoods, FL. USA
  • Bill ChennaultBill Chennault Posts: 1,198
    hank van buren--
    Will your motors draw 35 to 40 amps in real-world situations?
    I have a robot with motors that CAN draw 85 amps each. Both of them are run by seperate HB-25s. In use, I doubt they ever draw as much as 15 amps, even when running in tall grass, tearing the heck out of my lawn as the grass gets caught up in the tracks and is ripped from the ground.
    Think about what your motors will actually draw. If you cannot devise a test and really need the capabilities of the HB-25, try one and see if it works. If the magic smoke blows . . . you were wrong. [noparse]:)[/noparse]
    --Bill
    You are what you write.
