Need some ideas!! ASME automated waste sorter (AWS) — Parallax Forums
splashsplash Posts: 1
edited 2009-09-25 04:54 in Robotics
hi people!!
i'm in a real fix.. i need to design an automated waste sorter. specifications described below.
in short i need a way out to differentiate glass plastic ferrous and non ferrous materials.
i'm thinking upon using IR radiation technique which would involve a IR producer and sensor.
all these four materials absorb or reflect IR radiations in different amounts. and so throwing IR on each of them and then collecting it on the other side with a sensor, i can possibly differentiate among the for materials.
but this method seems quite complicated for an autonomous robot.
SO I"M DESPERATELY SEEKING your ingenious suggestions over this.
please help. if you can think of some other ways of sorting out the four materials, please please enlighten me!!
there are twelve (12), randomly‐distributed waste products, specifically:
1. Three (3) empty, irregularly‐shaped plastic bottles, measuring approximately 75
mm (± 20 mm) in maximum diameter and 220 mm (± 20 mm) tall.
2. Three (3) empty, irregularly‐shaped aluminum cans, measuring approximately 65
mm (± 20 mm) in maximum diameter and 120 mm (± 20 mm) tall.
3. Three (3) empty, irregularly‐shaped tin‐coated steel containers, measuring
approximately 75 mm (± 20 mm) in maximum diameter and 110 mm (± 20 mm)
tall.
4. Three (3) empty, irregularly‐shaped glass containers, measuring approximately
60 mm (± 20 mm) in maximum diameter and 95 mm (± 20 mm) tall.
we have to design, build, and test a system capable of rapidly and accurately sorting the
four waste materials noted above into distinct waste containers. The system must operate
autonomously and be capable of both material identification and waste handling. we have to do this ion minimum time.
Device Requirements:
The AWS must autonomously identify, handle, and sort the aforementioned
waste products.
The AWS must be powered by readily‐available, over‐the‐counter, dry‐cell,
rechargeable batteries.
The AWS must have a readily‐accessible and clearly‐labeled master shut‐off
switch.
To ensure ample space, the entirety of the AWS must fit within a container
measuring, on the inside, 340 x 580 x 400 mm. The AWS must fit within this box
fully assembled. Any expansion or extension of the AWS must be done
autonomously by the system itself during the competition run.
The five (5) waste containers
– one for each of the four (4) groups of waste products and an additional (1)
container for unsorted/unclassified objects – must be clearly labeled and
transparent.
breaking of glass materials is forbidden.
also the robot shouldnt be bulky!!
Distortion of waste containers in the sorting process is allowed.
Post Edited (splash) : 9/24/2009 10:36:03 AM GMT
  • WBA ConsultingWBA Consulting Posts: 2,936
    edited 2009-09-24 16:38
    IR may not be the way to go since the bottles in question would vary in regards to labeling, etc and the labels may play a part in the IR results. Look at Contest Operation #1 and FAQ# 906 for the design contest you are referring to.
    http://forums.parallaxinc.com/secure.asme.org/designcontest/faq.cfm?faq_year=2010
    www.asme.org/Events/Contests/DesignContest/2010_Student_Design_2.cfm
    You will need to look at some other sort of sensor or backup the IR sensor with a secondary sensor that can account for the variances in readings caused by labels, paint, etc. you may want to peruse the Sensors forum and see if you can get any ideas.
    Andrew Williams
    WBA Consulting
    WBA-TH1M Sensirion SHT11 Module
    Special Olympics Polar Bear Plunge, Mar 20, 2010
    edited 2009-09-24 17:26
    By having a coil in the gripper you can detect and separate the steel cans by the load on the arm when the coil is energized with a dc voltage. If the load does not increase when the coil is energized with dc an ac voltage can be used to determine if it is an aluminum can. If it is not an aluminum can then it must be glass or plastic and the load on the arm should be enough to determine which one it is.
  • ManetherenManetheren Posts: 117
    edited 2009-09-24 18:14
    if the gripper cannot sense metal then have it go over the glass bin and cruch the opbect, if it breaks it is glass and if it does not then it is plastic.
    Tia'Shar Manetheren
  • Marz KrishnaMarz Krishna Posts: 26
    Use The electro magnet to separate the tin cans, then use a lamp and a light sensor to detect translucent or transparent glass. an electronic scale to distinguish between opaque glass and plastic/aluminum. Dinstinguishing between opaqe plastic and alluminum can be tested with electrodes and checking conductivity. you would also need feelers to distinguish size for accurate weigh monitoring.
