Do I need a "latch" to capture a momentary button push.
I'm just getting started with the BS2 and I am attempting to build a device that will send basic telemetry from a couple of cars to a base station. I want to be able to detect when the driver has pushed a button in one of the cars. I plan on using the XBee Pro XSC RF modules for communication. I had planned to have the base unit poll each car unit and have the car units send back their data. However, if the driver pushes a button (momentary on) and the BS2 isn't looking at that input, I am assuming that it won't register. Do I need to use a latch (with a 4043) and just reset the latch once I have read the value? Or am I making this more complicated that it needs to be?
Thanks!
Andy
Thanks!
Andy
Thanks!
Andy
Don't worry. Be happy
Here is a chip carrier that carries a 16 channel GPIO that you can put in your breadboard.
http://stores.shop.ebay.com.my/GravitechEstore__W0QQ_armrsZ1QQ_fsubZ18905089
-Scott
Can you share the code that you use with the MCP23008
Thanks for your time and help that you can give
··Thanks for any·
Sam
