Strings
I've just spent a little time browsing through the object exchange, and there have been some great additions over the last 6 months! And I have found a nifty string library by Brandon Nimon (maybe there are others too - any pointers would be most appreciated). Brandon's code has for example:
Which prints a smaller string.
Is there a way of storing the values, rather than just printing them out?
eg in BASIC;
I've written some string handling for Z80 assembly in the past and, at the simplest level strings are just arrays of ascii characters. So
1) Arrays need to be defined as variables to store space for them
2) Strings need to end in a specific character (CP/M used $, but that means you can't print $, but I think ascii &H00 is the standard)
3) Strings can be variable or fixed length. MBASIC used variable length which saved space but every 10 mins or so, an MBASIC program would hang while it sorted out its strings. Fixed length makes more sense, and SBASIC used 32 bytes which seems to work well.
So my question really is, how do you go about defining space for strings before using them?
Is it a matter of declaring an array of 32 bytes (is that 8 LONGs?). Then filling those bytes with ascii zero so it is a blank string with zero length?
Then perhaps a subroutine where you pass it the name of that array and the bytes to fill it with. ie the equivalent of A$="Hello", something like 'definestring(stringname,"text") ' or 'fillstring'. Then passing the address of that array so you can manipulate it with string handling functions?
I see there is a STRING function in Spin but I'm not sure quite how to use it. Does it create the space for the string on the fly, or can you use it to permanently store strings somewhere? How would I go about writing the complete code in Spin for the following SBASIC code:
www.smarthome.viviti.com/build
debug.str( string("SubStr-demo starting at right end of string",13)) debug.str( string("STR.substr(string(´1234567890ABCDEFGHIJ´), -18, 7))",13,13))
eg in BASIC;
A$="Hello " B$="World" C$=A$+B$ rem store the new string in C$ before printing it ... PRINT C$
var mystring1 as string:32 rem reserve 32 bytes for mystring1, fill with null bytes var mystring2 as string:32 rem reserve 32 bytes for mystring2, fill with null bytes var mystring3 as string:32 rem reserve 32 bytes for mystring3, fill with null bytes mystring1="Hello" rem put 5 bytes in mystring1 and terminate with a null byte mystring2=" World" rem put 6 bytes in mystring2 and terminate with a null byte mystring3=mystring1+mystring2 rem concatenate strings (possibly needs a function call rather than the implied function call in '+') rem , eg str_concat(string1,string2,string3) mystring3=left(mystring3,5) rem put the first 5 bytes in mystring3, terminate with a null and erase the rest of the bytes
As far as Spin is concerned, strings are just byte arrays that use a zero byte as a string terminator. If you want a 32 character string, you have to declare a 33 byte array and initialize the first byte to zero if you want an empty string.
That is great. Many thanks - that makes a lot of sense and comes out almost the same number of lines. Now I can see a way to add some of the other string functions that I have in Z80 assembly - left(), right(), mid(), instr(), chr(), str(), hex() et al. This might be relevant for the various BASIC projects going on at the moment too. Cheers, James
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Steve
Steve
Steve
