Memory Usage & Dec to Hex
To anyone interested:
Peter - thank you for your dec to hex help,
·········· your last example worked great.
Now that my interest has peaked in a dec to hex converter,
below is some code that I think could replace your example
without utilizing the (import stamp.util.text.*) method bprintf··
PETER'S:
static char[noparse]/noparse cBuffer = new char[noparse][[/noparse]60];·····
while (fingerReceive.byteAvailable() == true) {·
int b = fingerReceive.receiveByte();
cIndex = Format.bprintf(cBuffer,cIndex,"%02x",b&0xFF);
MINE:
The method below returns the same results as above
except this routine slowly uses more memory(VERY BAD)
I've detected with a periodic call to: System.out.println(Memory.freeMemory());
Can anyone tell me why the sub Dec2Hex EATS MEMORY?
All variables are declared static outside the function.
ANY FIX TO MY MEMORY EATER WOULD BE APPRECIATED
NEW:
buffer.append(Dec2Hex(b&0xFF));
static String hex;
static int digit;
static int length;
static String [noparse]/noparse HexCodes = {"0","1","2","3","4","5","6","7","8","9","A","B","C","D","E","F"};·················
· public static String Dec2Hex(int d) {
······· if (d == 0) return "00";
······· hex = "";
······· while (d > 0) {
··········· digit = d % 16;
··········· hex = HexCodes[noparse][[/noparse]digit] + hex;
··········· d = d / 16;
······· length = hex.length();
······· if (length < 2)
······· return "0" + hex;
······· else
······· return hex;
Jeff (trytryagain)
PETER'S:
MINE:
NEW:
static String hex;
static int digit;
static int length;
······· hex = "";
······· else
······· return hex;
Jeff (trytryagain)
"0" + hex
The javelin creates a temporary string each time and since there
is no garbage collection these temporary strings are not returned
to the heap.
regards peter
I dub you Peter The Great!
My lesson here is stay away from concat with +
This also taught me to monitor memory at all
times. Progams won't loop for long with leaks.
Thanks again my friend
Jeff (trytryagain)
