no basic stamp found — Parallax Forums
dhcarstensdhcarstens Posts: 11
edited 2009-09-24 14:30 in BASIC Stamp
I recently purchased a MoBoStamp-pe and it was working fine over a couple of weeks.· Now when I try to program it I get a "no basic stamp found" error and a 'can't open port; in use" message shows in the download progress box. It is currently running a program
I tried resetting the board or downloading the loader software again and·nothing helps.· Any ideas?
  • Redd DawgRedd Dawg Posts: 26
    edited 2009-09-23 16:59
    Here you go...
    http://forums.parallax.com/forums/default.aspx?f=5&m=386161
  • dhcarstensdhcarstens Posts: 11
    edited 2009-09-24 13:01
    Thanks for your info. I think the problem was the MOBO was running a program that had DEBUG statements. I turned it off when not in use and when I turned it back on, the program was still running making the computer think it was a serial port.
    Working through the suggestions finally did the trick. Here's what I ended up doing:
    --pulled the USB line from the board
    --reloaded the stamp editor
    --reloaded the USB driver
    --reset the computer
    --pulled the power pin (choosing between USB power and external power to the stamp)
    --attached the USB connection to let the USB interface start up (interface is powered separately).
    --put back the power pin on USB power, starting up the computer
    --loaded and run the program
    I'm not sure reloading the programs were necessary.
    In the future, I'm going to run a simple program:
    ' {$STAMP BS2pe}
    ' {$PBASIC 2.5}
    END
    before I power down the stamp to make sure it's not running debug operations.
    Mike always has the answers...
