Convenient PASD Enhancement — Parallax Forums
pjvpjv Posts: 1,903
edited 2009-09-24 21:00 in Propeller 1
Hi All;
I'm not sure whom to direct this post to, but I'm using PASD to assist in debugging assembler code, and I find it a very useful tool....... many thanks to its creators.
I do wonder if it would be possible to have a small? tweak made to the "SAVE SETTINGS" command so that it also saves the fact that the COG/MAIN ram viewers are open, as well as their properties such as size, screen position, and window dimensions.
I'm bouncing in and out of the debugger a lot, and every time I re-enter, I must manually restore those settings. It would be great if I could choose to have them "remembered".
Again, thanks so much for this wonderful tool.
Cheers,
Peter (pjv)
  • HarleyHarley Posts: 997
    edited 2009-09-23 01:41
    I too second the suggestion. This would be a user friendly improvement.
    I use PASD quite a bit and restarting is a nuisance having to bring out the three windows, position them from off the listing, and then begin. Phew! yeah.gif
    Harley Shanko
  • AribaAriba Posts: 2,690
    edited 2009-09-23 02:58
    OK, I have made an extended version 0.4 of PASD.
    This version stores the properties of all Window in the INI file, and also allows to enable/disable the "Always on Top" mode of the Viewer windows.
    Now the code for the first Cog should be executed, if more than one Cog is written in one file.
    You can download the new version on my Propeller website:
    www.insonix.ch/propeller/prop_pasd.html
    I had to restore the source code from Backups, because I had a harddisk crash, and lost version 0.3. I hope all the old features still work as before.
    Andy
  • pjvpjv Posts: 1,903
    edited 2009-09-23 18:49
    Andy;
    Thank you so much for paying attention to that nagging little detail! I makes us more efficient, and we really appreciate it.
    Things seem to be operating properly.
    Cheers,
    Peter (pjv)
  • DroneDrone Posts: 433
    edited 2009-09-24 08:56
    Andy, One more thanks! This is great. Really enhances PASD. David
    Have tried this latest improvement. It's great.
    Thanks Andy,
    Harley Shanko
