Measuring AC Voltage
I'd like to use the Basic Stamp to measure AC line voltages, but am not sure about the interface circuit.
Possibly convert to DC, then use a voltage divider circuit?
All comments are welcome.
Thanks...
Thanks...
- Stephen
- Stephen
·I'd like to be able to reflect the 120 AC line voltage as if measuring on a voltmeter.
Use a·9 volt transformer to make 120· volts this might be Little closer but may be harder to find
·Allot saver than 120 volt AC· and easier to do Trust me on this one
I agree with·Mike Green what is in his Post
Here is something that might work for you it is 12 at 150 milliamps
Now what I have done in the past is load the power supply with (ADD enough)·LEDs to bring the NO LOAD voltage·to 12 volts and just move (.)·to the Line Voltage value
http://www.mpja.com/prodinfo.asp?number=17565+PD
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/24/2009 1:23:51 AM GMT
