propreller Boot loader
Hello every one.
I have a question about the boot loader program.
From where the boot loader programs comes from is it comes from outside environment? and does it stores the program on the HUB memory or in cog memory? if so then what if power turns off? do we need to reload the program after power goes off?
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
The boot loader program is stored in the Propeller chip's ROM. It stores the program received from an attached PC into HUB memory or copies a program found in an attached standard 32K byte EEPROM to HUB memory. If the power goes off, the Propeller's memory gets erased and the boot loader is executed again (from ROM) when the power is restored.
