changing a crystal — Parallax Forums
changing a crystal
ksamksam Posts: 19
edited 2009-09-20 16:49 in Propeller 1
I am trying to change the crystal size in abinary folder for the game frogger that was posted.· How can I get into the binary folder to change it from a 5 to a 6.25 crystal?
    Do you mean "binary file" instead of "binary folder"?
    It's possible, but not simple to change the crystal speed in a binary file. The 1st four bytes of the binary file contain the system clock speed which is normally 80MHz and you'd have to change that to 100MHz (6.25MHz * 16 = 100_000_000). The problem is that there's a checksum in byte #5 of the binary file that also has to be changed. It's really much easier to just change the source code and recompile since the compiler will recalculate the checksum for you.
