SX-Key (USB) Dose any one at Parallax......Problem it load program codes but wi
USB_SX_Key·
No matter what you choice whether it is···· ·step, walk or ·run······· it shows· ether·idle or sleeping
yet if I use the Serial_SX_Key that work the right way this is all·done on the same board SX_28_Proto_Board
I uninstalled·the·USB to Serial adapter·Driver ( with the·FTDI USB Uninstaller) that was on· the computer an reinstalled the new version and still the same thing
With version 3.30 I can down load the program code with no problem and it works ·but I·can not debug and the blue light stays on SX-Key USB one
With version 3.23· I can down load the program code and it work but there is an error that communication has failed and will not·Debug either but I get the error· that communication has failed and the blue light goes off
There is also one more thing the SX Key Board get very warm to the touch I do not know if this mean any thing or not
·Dose any one have any
·to what is going here
Here Is the code that I am using
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 9/20/2009 8:19:50 PM GMT
·to what is going here·
··Thanks for any·
Sam
I have try-ed every thing that·I know to get this to work
Thanks for any help that you can give me
··Thanks for any·
Sam
Try changing the OSC1MHZ to OSC4MHZ and see if it works.
Bean
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Thank you for calling; I will follow-up with you via email once I receive the RMA.
Respectfully,
Joshua Donelson
www.parallax.com
Bean I try ed what you posted and it do·not make a difference It still would not Debug that when·I called Tech Support
Thanks for your reply and help
I just LOVE these people At Parallax They always help you when you can not get some thing to work right
Thanks to every one at·· Parallax· ·Sale and Tech Support·· and the Forum
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/22/2009 10:03:27 PM GMT
