Noobie Question about bad chips
If I have a bad Propeller chip, would a (F7) Identify Hardware work? I am trying to figure out if I have a bad chip. My suspicion is that I do not. The F7 comes back with "Propeller chip 1 found in COM 6". I must have bad wiring.
Ch3-Ex06 - Blinker1
{{ Blinker1.spin }}
OBJ
LED : "(Ch3-Ex06)-Output"
PUB Main
{Toggle pins at different rates, simultaneously}
LED.Start(16, 3_000_000, 10)
LED.Toggle(17, 2_000_000, 20)
I removed the 9-vold battery, unhooked it and put it away for a few weeks and when i pulled it out yesterday and plugged it all back in, my LEDs at pins 16 & 17 lit up for a sec and now will not.
I have tried other pins to no avail and have also tried this following code: (with appropriate LED at pin 3 and pushbutton at pin 18.
PushbuttonLedTest-v1.0
''This code example is from Propeller Education Kit Labs: Fundamentals, v1.1.
''A .pdf copy of the book is available from www.parallax.com, and also through
''the Propeller Tool software's Help menu (v1.2.6 or newer).
''File: PushbuttonLedTest.spin
''Test program for the Propeller Education Lab "PE Platform Setup"
CON
_clkmode = xtal1 + pll16x ' Feedback and PLL multiplier
_xinfreq = 5_000_000 ' External oscillator = 5 MHz
LEDs_START = 0 ' Start of I/O pin group for on/off signals
LEDs_END = 15 ' End of I/O pin group for on/off signals
PUSHBUTTON = 18 ' Pushbutton Input Pin
PUB ButtonBlinkSpeed ' Main method
'' Sends on/off (3.3 V / 0 V) signals at approximately 2 Hz.
dira[noparse][[/noparse]LEDs_START..LEDs_END]~~ ' Set entire pin group to output
repeat ' Endless loop
! outa[noparse][[/noparse]LEDs_START..LEDs_END] ' Change the state of pin group
if ina[noparse][[/noparse]PUSHBUTTON] == 1 ' If pushbutton pressed
waitcnt(clkfreq / 4 + cnt) ' Wait 1/4 second -> 2 Hz
else ' If pushbutton not pressed
waitcnt(clkfreq / 20 + cnt) ' Wait 1/20 second -> 10 Hz
I have checked the power connectors for continuity and have 3.2 volts across the board.
I do not think it is the chip with it able to validate an F7, since I was not doing anything extreme. But....
any ideas on where to look or check for would be appreciated.
Just to be sure, replace the battery.
