tv and rca
I need someone to explain the tv pins please. I am not an assembly language programmer. Please see bottom of TV.spin that is attached.
I am looking for the way to change the pin assignments for the rca jack and broadcast.
Thanks.
Thanks.
Your Demo program has a value for tv_pins of %001_0101. From the comments, this specifies that I/O pins 8-15 are to be used (the 001) and that the video output is baseband (video) in the upper 4 bits (top nibble - the 0101) of the group of 8 pins (in other words ... pins 12-15). The actual video output uses pins 12-14 and an optional S-video output is on pin 15.
If you want to change the pins used, change the "pins" value in "tvparams" in the Demo program and follow the description in the TV.spin comments.
