Repost with subject! Use of SD-card to update Prop. program
TonyWaite
I am working on a design for a Propeller datalogger application, with the aim that the user should be able to load updated versions of the main program simply by swapping out the micro-SD card.
The Obex shows a variety of possibilities for implementing such a function; some using disk OS's.
Assuming that this idea is sensible, I would welcome the collective advice of the Forum on the easiest/fastest route that they they would recommend!
Thank you,
Tony Waite
Thank you,
Tony Waite
*Peter*
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
When I have time to look at it properly I will have a resident bootloader in EEPROM that will load the firmware file directly. That way then there is no way I can lose the bootloader especially if i have a jumper on the write-protect of the EEPROM.
*Peter*
P.S. Welcome to the Propeller forum Tony
Post Edited (Peter Jakacki) : 9/18/2009 12:25:38 PM GMT
Searching the PropDOS threads has now given me more of the background. So thank you Cluso99. (I too
liveaboard -a 40ft quarterdeck cruiser!)
And I like Peter's 'quick comparison' method of managing the image on the SD-card too.
The Propeller is wonderfully addictive ...
T o n y
Parallax Engineering
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
This looks like a perfect match ...
T o n y
