GPS Module - Accuracy vs. Resolution
All,
Just want some clarification on the GPS module sold from Parallax:
The manual mentions accuracy (0.1 meters) as part of the specs, but is accuracy and resolution really the same? What is the best you can get out of this module?
TWilson
TWilson
- Stephen
Post Edited (Franklin) : 9/17/2009 11:25:45 PM GMT
Welcome to the forums.
This is not a simple question to answer.
a quick search on google under
accuracy of GPS
will show why.
The best I've gotten is about to within 6 feet. (Probably due to the GPS signals themselves.) But you have to be moving for this thing to output a new value. Overall accuracy increases the more sample data points you track. Take a look at one of Chris's (Parallax) projects that might be of assistance:
"GPS Datalogger using google earth"
http://forums.parallax.com/forums/default.aspx?f=21&m=379992
Cheers
- Howard
I wonder if it's a typo - doesn't seem possible, does it?
- H
Parallax Engineering
Resolution is how detailed the output of the instrument can display.
Take a DMM that is trying to measure 12VDC.
How accurately can the DMM measure 12VDC?
Once measured, how detailed is the resolution? e.i· 11.9V versus 11.9999V
The next step is repeatability.· If you measure the same output numerous times, how close are the measurements to each other?
Thats my take on it anyway.
