110 VAC power to stamp
Hello!
·I am looking for the best suited regulator to convert 110AC to 12VDC. I have several projects using a super carrier board that I will need to power.
I really hate the power adapters that plug into the wall and would rather do the converting inside the "box" on the SCB. Does anyone know of a converter/regulator and possibly a few other components that·I can·mount to the SCB·that will·be suitable for powering the SCB?
You probably won't find a cheaper power supply thats also safety certified than the wall-wart style. If you have a look at industrial power supplys for use in electrical panels, there are hundreds available from DigiKey and Automation Direct. In most cases they are many times the size (and cost) of the SCB.
A compromise would be to use an enclosure big enough to hold the SCB and the wall-wart. The cord would just be an extension cord with the socket end inside the enclosure to plug the wall-wart into.
While I don't recommend it, if you want to build your own, for safety you'll need an isolating step-down transformer, a bridge rectifier, one or two large caps. The big disadvantage to the inexperienced is that you will (potentially)now have 120 VAC on a board that is designed for only low voltage.
Tom Sisk
http://www.siskconsult.com
Steven
Experimenting with mains voltage is dangerous and can be fatal, so I do not recommend this unless you know what you are doing. You should know what a bleeder resistor is, and always protect yourself properly. In CRT screens with damaged bleeder resistor, there can be up to 10.000 volts coming at you even if the power isn't plugged in!
en.wikipedia.org/wiki/Rectifier
Don't worry. Be happy
