Help with Speech recognition code please!
Hi, I just CANNOT get this program to work. I have been working on a speech recognizer for Hanno's project and I have run into some trouble with (what I think is a final) prototype. When it "compresses" and compares the voice samples. it says that you sayed "right" no matter what you say. It is easy to use, try it for yourself. Just plug a Demo Board into a TV screen and follow the instructions on the screen.
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
Post Edited (microcontrolled) : 9/18/2009 11:55:07 PM GMT
Parallax Engineering
--Steve
Propeller Tools
If what you mean is really
then that's what you need to spell out in your program.
I think the problem with your message and perhaps why it didn’t generate any response is that you simply stated you have a problem. You didn’t really ask a question or offer any insight to what you think was happening and then solicit some assistance with it. When following up on a post that has generated no responses it is often a good idea to look at the original post and ask yourself how you would have responded to it had you seen it from someone else.
You're calling Main recursively. It sort of works because when rec is 7, you no longer call it. You could just put a REPEAT around the whole contents of Main to do what you seem to want to do.
You could simplify Main by putting the six almost identical word entry parts in a subroutine and passing them a string for the word to be entered and the address of where to put the compressed information, then just calling them in sequence like:
enterWord(string("right"),@right)
enterWord(string("left"),@left)
enterWord(string("up"),@up)
as you did not include the file "dual_ADC1.spin"
I was not able to compile your code
best thing to provide code is to use the archive-function
this will include ALWAYS ALL files that were needed to compile a top-objectfile
anyway I modified your code as suggested from mike
see attached file
best regards
Stefan
