dynamixle AX-12 control
hey man
i got the parralax demo board·and AX-12 from crust crawler. and i downloaded the dynabus program which containes a library for AX-12.
after programing the chip. i dont know how to comunicate with the servo and send the instruction packet.code ( 0xFF 0xFF ID instruction .........)
i can read the status packet using the test terminal. that reads that the servo is off.
my question is how cn i use the the dynabus code to control the AX-12.
please reply ASAP
thank you for your help
regards
Joy M.A
Mechanical Engineer
please reply ASAP
regards
Joy M.A
Mechanical Engineer
Thank you for posting, we will try to help we additional info is supplied.
(Its hard to help others out when very little info is supplied because so many things can go wrong).
Nyamekye,
