radio signals
Hi I'm new to the Basic Stamp but not new to programming. I need to send a radio signal reliably up to 1/2 mile based on a condition and then receive this signal for the purpose of performing a task. So I guess my question is: is there a way to send and receive a radio signal using the Basic stamp this far? I have a Board of Education project board.
Thanks in advance.
Thanks in advance.
You might have a look at some of the transmitters / receivers in Parallax's webstore. Digi also makes the xBee series of transceivers including some higher power (PRO) devices that, with a small attached antenna, could handle the distance. See Digi's website for further information on those www.digi.com
Post Edited (Mike Green) : 9/16/2009 10:57:36 PM GMT
There are other XBee modules, but they are 2.4gHz and don't have the range that the PRO XSC does. The PRO XSC is on the 900 mHz band.
Hope this helps,
Dave X
Edit:· Looks like MGreen & I answered at the same time!
Ken N8SYG
Dave
http://www.parallax.com/Store/Accessories/Communication/tabid/161/ProductID/582/List/0/Default.aspx?SortField=ProductName,ProductName
The product page claims a range of 2500 feet. But of course that doesn't change things - if you really need 1/2 mile, a unit that claims 2500 feet isn't really going to meet your needs, because you're not going to reliably get that distance unless you have clear line of sight above any obstructions.
I'm getting at least 3500 feet from regular 2.4 GHz XBee Pro modules, but that is with a very clear uninterrupted line of sight, mostly with the transmitter in the air. On the ground I was starting to have problems at 500 feet. If you really need 1/2 mile, you're probably going to need the 900 MHz modules that Xanatos recommended.
····http://forums.parallax.com/showthread.php?p=788294
However, the antenna connector on the transceiver is likely to be a "reverse SMA", designed to thwart attempts to use other antennae.
Post Edited (Larry~) : 9/17/2009 4:36:44 PM GMT
