Stud finders, really. any good hacks for these?
I had to run to Lowes for some stuff to finish my water heater and they had a bunch of really cheap Stud Finder on the clearance table 1 dollar each and they work fine . Stanley units I bought a few and was wondering if anyone has done any kind of
projects using stamps or prop chips? Can the range be extended like a Ping unit maybe ??
If you set the sensitivity just right you could use it like a proximity switch.
So that just touching the front of a panel would activate something..or maybe
just picking it up would. You could easily make use of the low current that goes to the studfinder's
indicator LEDs.
"Where am I? Where am I going? Why am I in a handbasket?"
I just bought 5 of these the all seem to work except one I have not taken them apart yet I am hoping there is something I can do with them maybe some type of sonar?
PG
They are somehow sensitive to any sort of mass.
You can set the sensitivity to where bringing
your finger right up near the sensor will cause the LEDs to light.
How about a capacitance-controlled Theremin? Cooool....
DJ
Instead of:
"Those who can, do.· Those who can't, teach." (Shaw)
I prefer:
"Those who know, do.· Those who understand, teach." (Aristotle)
Holly you never shared what you did with those cordless drill motors? I took one of mine apart but left the motor attached to the chuck with just a 9 volt battery the thing has lots of power its slow but it could move a lot of weight I'm guessing
