pls help with tis PS3 controller problem!!!!
This is really tough......
i had always interested in servo & PWM projects so 1 fine day i decided to try controlling a servo motor with my PS3 controller. My original idea was to write a program in C++ to extract the controller signal from the computer (yes is computer & not from bluetooth! i've done the bluetooth interface with computer part hence just getting the controller signal from computer will do) and pass the signal through the RS-232 serial port and to a PIC 16f84 chip to control the servo in a real-time pattern (for example, when i move the analog control of PS3 controller, the servo will move accordingly) Sounds easy?
i know, by downloading drivers from the internet would easily solve the problem but writing a program from scratch is really a big headache......
After trying for about 2 & a half month i give up......
Has anybody out there already done similar things? As a electronic fan u should understand the feeling of curiosity torturing when u want to experiment something but......
can somebody kindly enlighten me? or recommend me something? a circuit or program etc......
pls help! thank you thank you !!
- Stephen
