X,Y,Z IMU (accelerometer, gyro and compass)
This is a 9DoF IMU, it uses a tri-axis accelerometer, 3x single axis gyro and tri-axis compass.
The accelerometer is the ADXL335, the gyros LISY300AL and the compass the HMC5843. You can build this the breakout boards from sparkfun
http://www.sparkfun.com/commerce/product_info.php?products_id=9372
http://www.sparkfun.com/commerce/product_info.php?products_id=9373
http://www.sparkfun.com/commerce/product_info.php?products_id=9371
though I dont use this LISY300AL board.
It has also used with an ADXL330 accelerometer, 2x dual IDG300 gyros, CMPS03 compass with no code change to the IMU code
It uses a cutdown version of cessna's fixed point maths library, tuned for the IMU.
It has a I2C object for the HMC5843.
It uses a TLV2553 for the A2D, this is a faster version of the TLV2543. This A2D will work with the obex tlv2543 library but the object here is tuned for the tlv2553/tlv2556 and runs much faster - it samples at ~9000 samples/sec for each of the 11 channels
The IMU started from Jason Wood 5DoF IMU but runs an additional kalman filter for the Z axis. I have also moved the A2D access external to the object so other A2D/accelerometers/gyros/Compass can be used without changing the IMU code - also the midpoint and gyro gains are passed in during initialization.
The IMU updates at ~48 times/sec and uses 1 Cog for imu(imu, kalman filters and maths) + 1 cog for the A2D
Cheers,
Simon
www.norfolkhelicopterclub.com
Announcement: To cut costs in the current economic climate, we have switched-off the light at the end of the tunnel.
What are you controlling? Do you have a pic?
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
The black SMT cap oppersite side of the board from the connector is the cap I put another one in parallel with. In terms of C1/C3 which schematic were you looking at, on the honeywell datasheet its C1, I think it was C3 on the sparkfun schematic.
@Cluso99, I had to put it on one side for a while due to work and other stuff. I have started picking up my bot stuff again though I haven't got to that yet. I dont have a picture of it but I can take one and post it. The code is setup so the sensors and kalman filters are separate and link through hub varables, so its easy to change the sensors without changing the filters. There is some configuration tables that·specify the gains of the sensors so if you change the sensors, you can change the config table and the filters will work unchanged.
Its currently an overkill for what I use it for - bot navigation but most of my bots use one set of code and are configured for H-bridge, sensors etc. so the idea was to integrate it into by code framework and its easy to use on any of my bots. I dont see any major issue changing it for the different accelerometer and gyros.
Digikey PN PCC2395CT-ND / ECJ-1VB0J106M
Panasonic ECG Ceramic 10uF 6.3V X5R 0603.
Small, lowESR
with success
x:4128 y:256 z:8192
x:5119 y:-1 z:-1
x:4128 y:256 z:8192
x:4128 y:256 z:8192
Thanks Tim. Yes the prop rocks for these apps because the code can be segmented easily with multiple cores.
Lots of propeller based products in stock at affordable prices.
I have the newly released gyro chips ITG-3200 too - arrived in Australia today so I will have them tomorrow/Monday
I am including a pressure sensor as well so hopefully we can sense ground level when returning. And a GPS can be added plus ultrasonic sensor (parallax) to do ground sensing.
Here is the link http://forums.parallax.com/forums/default.aspx?f=25&m=436063
Yes, the 10th is Pressure. I did not count Temperature. GPS and Ultrasonics will add another 4.
The SCP1000 apparently is going obsolete so I will use the BMP085. It is a little less sensitive but cheaper.·The Ultrasonic Sensor from Parallax for ground proximity for·when close to the ground can be added simply, as can the cheapie GPS from Parallax for $25 including inbuilt antenna.
My parts are now in Australia - Gyro, accelerometer, compass, pressure, GPS. I already have props.
The pcb design is well underway. It also has the RC inputs and ESC outputs on the pcb. The prop should do a really great job at this with it's multiple cores.
Tim, you are quite a bit more advanced than we (on the quadcopter thread) are, so your work will be a great advantage to us. Hanno has also done quite a bit of work in this area, and so has Jason Dorie. I am really excited with this project.
16 prop pins will have 0805 smt resistors for protection. These are intended for up to 8 RC Rx channels and up to 8 Tx (ESC) or servo channels. They are brought out to 2 sets of 8x3 0.1" pin stakes (or holes if not fitted).
All my parts have arrived including the ITG3200's and BMP085 and SCP100-D11. I also have the Parallax GPS module.
I have a new microSD slide socket which locks the card in. However it is a little flimsy so I an unsure if I will use this or the one I use with RamBlade/TriBlade which is a more secure socket. I can probably find the space to put a hole (for a cable tie) on the edge of the pcb just past the uSD card to prevent it from popping out under flight.
I have verified driving the motor esc via the prop - works nicely. I have yet to order all my mechanicals.
