BS2SX Help
Hello all. New member, new to electronics.
I have a BS2 and a BS2SX. I am running some tutorials and I can get the BS2 to work but not the BS2SX. Do I need to do anything else besides switch the "Stamp" from BS2 to BS2SX on the Basic Stamp Editor? I can switch between tutorials and do everything with the BS2 just fine!
Any tips or suggestions?
Thanks!
Thanks!
·What ·Basic Stamp Editor Version You should be using 2.4.2 if you are using· version 2.2.6 It will not work
to check what version you have all you have to is go to help while you are in the Basic Stamp Editor and go to about
then there will come with a window that will tell you what version you have
I hope that this helps
··Thanks for any·
Sam
