VHF Transceiver — Parallax Forums
VHF Transceiver
MilitaryRadioMilitaryRadio Posts: 18
edited 2009-09-16 17:03 in Propeller 1
Hello Friends,
The Italian radioamateur website published my VHF Transceiver project based on the Propeller CPU. You can view the document at this url:
http://www.ariroma.it/docs/projects/prop-4m.pdf
I'm sorry, at the moment the document is only in Italian, soon I'll write an English version, anyway I think it is possible to understand everything looking at the pictures and schematics.
Bye
Paolo
  • kb2hapkb2hap Posts: 218
    edited 2009-09-15 13:25
    Looks real nice! Cant wait for the English version! suppose I could go and google translate it.
    Great work
    DTQ
  • MilitaryRadioMilitaryRadio Posts: 18
    edited 2009-09-15 13:57
    Thanks, I believe it's the first radio based on propeller CPU.
    Now, I'm designing another transceiver on 2 meters (144 Mhz) that has the same controller card.
    edited 2009-09-15 14:49
    Im sure there will be alot of interest with that, especially for APRS keep us updated
    DTQ
  • nightwingnightwing Posts: 56
    edited 2009-09-15 16:02
    Very nice!
    edited 2009-09-15 16:12
    Awesome!
    "Where am I? Where am I going? Why am I in a handbasket?"
    edited 2009-09-15 16:15
    Paolo,
    I don't read Italian, but it's easy to tell from the photos and diagrams that this is an amazing piece of work. Congratulations!
    edited 2009-09-15 16:32
    The radio needed a lot of work but it was a great satisfaction to get it working.
    edited 2009-09-15 19:48
    Wow! Congratulations on a great project. Great job putting all the info together as well. Are you re-typing for the English part? Personally I would use Google language tools to convert a page at a time and then fix it up a bit if it's not 100% correct.
    Bob : VE1RLL
    Here's an example from your Italian Ver :
    Introduction
    When it was granted to amateur radio by the Ministry of Communications the opportunity to testing of transmission and reception on the 70 Mhz decided to make a transceiver on this band.Unfortunately, the construction of radio has taken at least two years of time and when it was completed on Ministry of Communications had revoked the license to use the 4 meters. If in the future will once granted, then this transceiver can be used in meantime can only be considered a laboratory experience.
    The transceiver is a device that I realized synthesized FM, driven by microprocessor mounted not only discrete SMD. I prefer the traditional components SMD components it is certainly easier installation and when working on prototypes welding is easier and you can use the sockets for the IC.
    This radio was designed by adopting a technique that computer scientists call "bottom up" by upwards. I started from individual components - the CPU card, card receiver, card transmitter - and I landed a full radio. Designing device at a Once you can focus your attention on the individual parts, putting them to work in point with the instrumentation and then assemble them together.
    First I designed and built the controller board, initially working on cards millefori then land a real double-sided PCB. The controller card has designed with the aim of being reused in other projects. The controller presents these interfaces: keyboard, LCD display, data lines generic input / output. On board the card I also provided a clock to store the date and time and an analog / digital converter (ADC)for the conversion of tensions in binary values. For programming is an integrated MAX3232 which allows direct connection to the PC serial port. As processor
    I decided to use instead of the excellent PIC microcontrollers typically used in this such projects, a micro controller is very innovative: the "Propeller" of Parallax. The propeller is a RISC microprocessor with 8-bit to 32 working in parallel for a computing power of 160 MIPS. http://www.parallax.com/dl/docs/article/Propeller_Firmware_magazine_ITA.pdf Some might object that this CPU is too powerful for a radio of this type, and
    surely this is true but to test an electronic component or software is required prove it is not enough on paper to study its characteristics. This radio can be regarded as a "test bed" to test the use of the Propeller and its interaction with the external components.
    Once the CPU has come the turn of the receiver. A site of components electronics (http://www.alltronics.com) I found a card that contained a surplus Tuner Mitsumi 407-A26. This tuner has a front-end Mosfet very sensitive, with a mixer output signal at 10.7 MHz and a VCO. The Tuner is able to tune into a range of frequencies from 60-150 MHz. The site also has the schematic and documentation. After
    I have unsolder the Tuner connected to a Fujitsu PLL used in some kits New Electronics and a MC3361 that is a narrow band FM receiver. The transmitter is certainly the least complex of the radio. 'When viewed from an oscillator VCO based on a New Electronic LX.1235 / 3 and the same used in the PLL MB1502 receiver. On the base of the TX are also relays for switching supply.
    Prop-4m rel. 2.0 September 2009
    Post Edited (Bob Lawrence (VE1RLL)) : 9/15/2009 7:57:17 PM GMT
  • DynamoBenDynamoBen Posts: 366
    edited 2009-09-15 19:55
    Wow, this could be a lot of fun to play with. It might be nice to turn this into a 2 meter radio.
    edited 2009-09-15 19:58
    Thanks for this suggestion, for sure I will save time doing this way.
    edited 2009-09-15 20:33
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
    · Search the Propeller forums·(uses advanced Google search)
    edited 2009-09-16 05:19
    Congratulations Paolo, you should be proud indeed.
    I have always been in awe of RF and have never really had much opportunity to play with it myself, so it's good to see such a design.
    As a note of interest we are always looking for unlicensed low-power digital transceivers and there are many chips and solutions around but if someone of your experience and caliber were to contribute a project along these lines I'm sure we would all be interested.
    I noticed from your schematic though that the digital control side can be improved and the component count could be reduced appreciable with just with a few simple changes. The 74C922 chip stood out as the first pin to bowl over smile.gif I am not qualified to comment on the RF side though, that's your department!
    *Peter*
    edited 2009-09-16 06:01
    Hi Peter,
    Thanks for your comments. You are right about the possibility of reducing some components in the digital card. This radio is just an homebrewed object build for personal use and not to be produced in large numbers. I consider this construction as a "Test bed" to discover Propeller functionalities. Now, on the experience of this radio I decided to design another transceiver (on 144 mhz) more affordable for cost and component availability.
    bye
    Paolo
  • VIRANDVIRAND Posts: 656
    edited 2009-09-16 07:08
    Hooray for a Software Defined Radio that looks like a radio,
    not a big black box with a usb port and antenna jack!
    I have it on my to-do list to make a 6-meter transceiver because I don't have that band
    and nobody makes a radio I like with it. (except YAESU 857D or FT-450 maybe?)
    edited 2009-09-16 08:12
    I don't know if the Propeller computational power is enough to manage the Analogic Digital Conversion for a SDR radio or it it is necessary to add an external ADC.
  • LeonLeon Posts: 7,620
    edited 2009-09-16 10:51
    It's not a software-defined radio; the Propeller is simply used as a controller. A PIC or AVR could have been used. The Propeller probably hasn't got enough computing power or cog memory for an SDR, even with a quadrature sampling detector (only an audio ADC required).
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 9/16/2009 12:54:31 PM GMT
    edited 2009-09-16 15:21
    Leon said...
    The Propeller probably hasn't got enough computing power or cog memory for an SDR, ...
    At frequencies where the Propeller's counter PLLs are relatively jitter-free, it's easy to build a tunable AM detector. This has already been shown here
    ····http://forums.parallax.com/showthread.php?p=743002
    in which a digitally-tuned receiver covering the AM broadcast band was demonstrated using only a Propeller. With a suitable RF frontend and broadband downconverter, I believe it's possible for the Propeller to take over duties as a tunable IF stage and audio processor. It remains to be seen, however, which modulation modes can be accommodated in this fashion.
    SSB on the HF bands is generally required by radio amateurs. Most low-cost amateur SDRs use a QSD converting the incoming RF to I and Q baseband signals that are demodulated using DSP techniques, usually on a PC, although low-cost DSPs like dsPICs have also been used.
    Lleon
