Voltage from USB when powered off? (Proto Board w/ Prop Plug and USB Proto Boar
Hey,
I was messing around w/ my USB proto board from UPENE, and noticed when I had the switch off, but the USB cable plugged in, the 3.3V line is about 0.7V, and the 5V line is about .2V. I thought maybe it was just the USB board, but when I checked my regular proto board w/ Prop Plug it gave me the same readings... has anyone else seen this, is this normal, and is it okay?
DogP
DogP
DogP
Rgds, David
