Measuring Temperature Below 0 with a Sensirion. . .?
Can the Sensirion sensor measure temperatures below freezing? I've got one wired up exactly like the demo, running the demo code, and everything works great until I hit the below 0C point, then things get crazy!
SHT1x Demo
soT...... 1854
tC....... 6532.1º
tF....... 6546.9º
soRH..... 1924
rhLin.... 63.7%
rhTrue... 449.5%
Any ideas on where I might find out why this is happening?
-Jeff
SHT1x Demo
soT...... 1854
tC....... 6532.1º
tF....... 6546.9º
soRH..... 1924
rhLin.... 63.7%
rhTrue... 449.5%
-Jeff
Note that I only handle below zero temps in Celsius. . .I don't need F so I didn't update that code. But you'll get the idea when you look at it. . .pretty easy.
Here's what I'm reading NOW in my freezer:
SHT1x Demo
soT...... 2363
tC....... -16.3º
soRH..... 1236
rhLin.... 41.8%
rhTrue... 40.9%
-Jeff
Post Edited (everest) : 9/14/2009 7:47:06 AM GMT
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
I like to leave the temperature in twos complement form, and display it using a debug command that can handle either the positive or the negative:
Your approach is fine, but it does take unnecessary (IMHO) lines of code to separately compute and flag the positive and negative temperatures, and also separate routines to display them.
Tracy Allen
www.emesystems.com
-Jeff
@Tomvn, that should be its own thread topic, and I see you have one already. Maybe you should edit the title of your thread so that it also focuses on the radio aspect.
Tracy Allen
www.emesystems.com
-Jeff
