Parallax Continuos Rotation Servo-Angle
Is there any formula, etc to find the "angle" of the servo mentioned in the topic?
The situation is I have a servo fixated to a table, and it has, for example, a PING))) sensor. The starting position relative to the design is 0 degrees. When I have for example
how much does the servo angle change.
Pulsout 12, 740
For a regular servo, every 10 uS of pulse width is roughly 1 degree of movement. In your example 740 is the same as 1,480 uS pulse width - which is 20 Us different from the center setting of 1,500 uS, which would then be about 2 degrees.
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
Between a continuos rotation and a standard servo, yes. For more accuracy you could use a high quality digital servo. Look for one with the lowest dead band.
For the most accuracy you would need an encoder.
Rich H
