Nes lightgun — Parallax Forums
Nes lightgun
FredBlaisFredBlais Posts: 395
edited 2009-09-14 15:59 in Propeller 1
Hi, I just found an old lightgun for the nes and wanted to interface it with the Hydra. I wanted to know if it is possible to get the x,y coordinate on the screen where there is a hit, or we only can detect white spot with it. Thanks!
  • VaatiVaati Posts: 712
    edited 2009-09-14 13:45
    Ummm... I have tried this many times... No--it is not possible with the HYDRA's setup, because the lightgun uses the other two pins on the NES socket:
    http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/s2003/lbb23/duckhunter/hardware.htm
    That page also describes how the lightgun works.
    I did find code for the lightgun, but it is a modified zapper using the light to freq converter. If you want, I will post it.
    Hope this helps,
    Forest
    Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
    *-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
  • FredBlaisFredBlais Posts: 395
    I knew for the 2 pins, I'll have to connect wires to the connector and feed it via the experimenter card (finally found an utility to it!)
