Question about how GPS works.
I am reading what seems to be a generally fine book, but I'm bothered by this line:
"For example, a GPS receiver determines its position on the surface of the planet by measuring the strength of received radio signals from several geosynchronous satellites".
By contrast, Wikipedia (which I believe to be correct) says:
"A GPS receiver calculates its position by precisely timing the signals sent by the GPS satellites high above the Earth. Each satellite continually transmits messages which include
The receiver measures the transit time of each message and computes the distance to each satellite. Geometric trilateration is used to combine these distances with the satellites' locations to obtain the position of the receiver. "
GPS position isn't really computed from relative signal strength, is it? I was very surprised to see that line in the book, but I suppose it's possible that I'm the one who is misunderstanding this. What do you think?
- the time the message was sent
- precise orbital information (the ephemeris)
- the general system health and rough orbits of all GPS satellites (the almanac).
Dave
- Stephen
(pd-ps1) = c (tr-ts1), (pd-ps2) = c (tr-ts2), (pd-ps3) = c (tr-ts3), (pd-ps4) = c (tr-ts4)
now the start position (ps1-4) are known - satellite position so geometry says there are 2 possible positions - one inside the satellites and one outside. So we assume the position is inside - unlikely you are more than 12000 (thanks sylvie369 for correcting me) miles above earth [noparse]:)[/noparse]. Now you are told ts1-4 (part of signal), you know the ps1-4. So you are solving for pd and tr, the receiver position pd (which is long, lat and altitude) and the receiver time tr. Algebra says if you have 4 equations and 4 unknowns you can solve the equations.
The c above is the speed of light in vacuum, this is a simplification since radio signal from satellites doesn't travel at c through the earths atmosphere. Receivers have a model of the atmosphere to caculate c for different times of day etc. but this is where some of the gps inaccuracy comes from.
Post Edited (Timmoore) : 9/14/2009 4:20:14 PM GMT
Edit: Oh, I failed to notice that the quote from the book at the start of the thread contains that same mistake. It's an understandable one, though. I used to assume they were in geosynchronous orbit myself, until someone corrected me in an online forum. Nonetheless, two mistakes in one sentence about GPS makes me wonder a bit about how dependable that book is going to be.
Post Edited (sylvie369) : 9/14/2009 4:29:53 PM GMT
- Stephen
