Can't find prop, need help.
It's me again, I got my PCB in the other day and got everything soldered to it fine (easier than it looked, and kinda fun), but I can't get the prop tool to recognize it. I keep getting the same "no propeller chip found on any serial port" message. It recognizes my uoled-96-prop when that is plunged in though.
IMAGE OF PCB FILE
I have tried both with and without the pull-up resistors on the rx, tx, and res lines.
Any ideas on why it doesn't work? I'm stumped but I am sure its just a stupid mistake, I am new to all of this.
I've attached the PCB file, it's for ExpressPCB if anyone uses it.
IMAGE OF PCB FILE
www.parallax.com/Portals/0/Downloads/docs/prod/prop/32200-32201-PropClipPlug-v1.3.pdf
I have the BOEn pin tied to VDD, could that cause the problem?
Post Edited (SexieWASD) : 9/13/2009 1:49:25 PM GMT
What would be the best way to interface the encoders, I can't find 3.3V ones.
Searider
--Steve
Propeller Tools
It is getting a stable 3.3V on all of the vdd pins, and all of the vss pins have continuity with the ground plane. I have tried two 5MHz crystals, both from the parallax store.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 9/13/2009 7:28:16 PM GMT
1) Double check to ensure that the Propeller RX pin is connected to the COM device TX pin (Propeller TX should be connected to the COM device RX pin). If there is a short on RX/TX, it can also cause trouble.
2) If you hit F7 or F10 on the Propeller tool, the RESn pin should drive low briefly from the COM device RES pin. If not the Propeller will not respond properly. An LED attached with anode on RESn and cathode to VSS might blink. Most people can see a 50ms pulse, but I'm not sure how big a pulse the Propeller tool makes.
3) If your Propeller is receiving > 3.3V on any pin, that pin should have a series protection resistor on it. The effect of driving 5V directly might be a warm device but it should not cause catastrophic failure on the whole chip. Other effects in run time would be input not having effect on your program.
Don't know what else to add now. Good luck.
--Steve
Propeller Tools
It was the Rx Tx lines, a quick swap on my cable and all is good.
Thank you much.
And yea I don't have the schematic only the PCB file, I just started with reading datasheets and making traces.
--Steve
Propeller Tools
Interesting circuit. I need to get some digital pots to play with.
Good luck with it.
@jazzed
Good job with the diagnosis . Actually, you got ripped off. It should have been a least two cookies.
--Steve
Propeller Tools
It's a hollow body strat with a flat top + f-hole.
Tiger maple neck.
macassar ebony fret board with an inlay of Cerberus in pearl.
quilted maple top plate dyed green + yellow.
redwood burl backplate not dyed.
all black hardware, with no pick guard.
I think I have spent near $1500 just for materials, not including shipping, or anything to do with this circuit. The most interesting part is that the entire thing was cut with a home built CNC router table by my brother.
Here's a few pics of a guitar body he cut just before mine to show off his craftsmanship.
A friend of mine makes his own guitars ... and plays the heck out of 'em too.
--Steve
Propeller Tools
When i hit F7 in the propeller tool i get communication error:
No propeller chip found on any serial port.
I made my own custom programmer and am using the 28-SSOP FT232RL chip and followed the schematics shown in the prop plug pdf for the corresponding pins in the 28-SSOP package.
I took an oscilloscope and am able to see the bits being sent.
I opened a hyperterminal and set it to 115200 baud rate and tied both Rx and Tx pins together and verified that what i typed was what was seen back at the terminal.
I've verified every pin on the board that holds the propeller chip with a multimeter.
I've downloaded and installed the drivers from the propeller tool - that did not fix the problem.
I've downloaded and installed the drivers from the FTDI site as well as the Mprog executable.
I've erased and reprogrammed the FT232RL.
I'm on windows xp and the drivers are shown to be installed and working properly. I have VCP checked which was why i was able to open the hyperterminal.
I've also desoldered the propeller and soldered a new one.
I'm using the schmartmodule dev board.
any ideas?
I'd be interested to see what sort of cavity configuration you have to give it a hollow body. Are you using a fixed or floating bridge?
Who's pickups are you planning on using? Are you planning on burying a piezo in there somewhere to exploit the acoustic properties of the cavity, or is the f-hole just for looks?
That's a nice looking tele-variant in those photos. Are they Gibson P-90 pickup routes?
lt's not particularly silly, is it?
Are you getting the right shaped pulse on the reset line when you hit the DTR ?
I'm using the following pickups.
Neck: Dimarzio area 58
mid: Dimarzio YJM
Bridge: Dimarzio Steve's Special
I may switch out the pickup's later as my brother has started winding his own, and I would like a set of true single coils to play with.
The bridge is a tune-o-matic bridge from graph tech with a piezo pickup in each string saddle.
I may install an acoustic style piezo at some point just to play with, but the f-hole is mostly for looks.
I'm not sure what pickups went into the arch top.
@propellerheadsz, these settings seam to work for me.
Bits per second 115200
Data bits 8
Parity None
Stop bits 1
Flow control none
Receive Bytes 4096
Transmit Bytes 4096
Latency Timer 1
Minimum Read Timeout 0
Minimum Write Timeout 0
Serial Enumerator checked
Post Edited (SexieWASD) : 9/15/2009 7:01:46 AM GMT
There is nothing like the twang of a nice single coil.
I've never heard piezo's in a Strat. I look forward to hearing what it sounds like!
There's not a lot of meat in the centre of the guitar by the time you route out the pickups and trem springs, so I think you may suffer a lack of sustain. On the flip side, if you make sure the top is nicely secured and braced, both sides of it should sing nicely and with different resonances. If that makes it back up to the bridge via the trem posts then you should get some interesting harmonic resonance through your saddle pickups. It should howl like a banshee in front of a good amp with lots of gain. Make sure your pickups are wax or epoxy dipped to keep the pickup feedback away and let the body resonate.
All in all it sounds like a really interesting machine. Now you just need to add some small linear drives and make it self-tune [noparse]:)[/noparse]
--Steve
Propeller Tools
I think i need a different npn pull down transistor...
does anyone have any recommendations as a specific model as it is not specified in the documentation?
How did you check the pulldown? The pulse is only about 10-15mS so you need to have the CRO set up right to measure it properly. It has a sharp falling edge, but the rise tends to float up a bit gently.
also, CRO?
Cathode Ray Oscilloscope.
You won't get any reasonable results on the reset pin without a CRO. The pulse is so short your DMM will see it as a glitch at best.
If you have dual trace, you should see the reset pin pulse low and about 100ms later you should see the first byte of the handshake come from the prop. (give or take 10-15ms either way)
It turns out that my recieve pin was not properly connected to pin 37 of the propeller chip. I resoldered and soldered still could not make a connection when i buzzed it with a multimeter - so I "hardwired" it to pin 9 of the J8 Header.
I am using the schmartmodule. Not sure if there is a problem with all schmart boards as none of you seem to be using this dev board.
hope this helps someone with the same board. Here is a link to the board i'm using:
http://www.schmartboard.com/index.asp?page=products_populated&id=205
but i actually got it at defcon so it looks really like this:
http://blog.schmartboard.com/.a/6a00e54ed57a3b88330115723c6c09970b-pi
